Author: Subject: Ignition Coil - Sparks everywhere
RobBrown
posted on 25/8/12 at 05:26 PM Reply With Quote
I have my engine running, but today I noticed that the ignition coil seems to spark between the + and - terminals and the HT feed.
All terminals have rubber boots on, yet still seems to spark. I can only put it down to the small gap between them all.
Is this normal?
Rob
bartonp
posted on 25/8/12 at 05:40 PM Reply With Quote
Is this normal?
Rob
Not normal - it's "tracking" - a HV breakdown over the surface.
If it's clean, the HV may be following a carbonised track or crack.
Clean & dry thoroughly, if it still does it it's new coil time.
Phil.
PS. That's why it's a good idea to open your bonnet in the dark sometimes.
RobBrown
posted on 25/8/12 at 05:43 PM Reply With Quote
I have another coil (new) which I tried and it did the same.
I will clean and dry everything.
snapper
posted on 25/8/12 at 06:15 PM Reply With Quote
Fully clean Coil HT connection and HT lead connection if still tracking
Swap HT lead
I eat to survive
I drink to forget
theconrodkid
posted on 25/8/12 at 06:54 PM Reply With Quote
normally caused by moisture,also a big gap,maybe carbon fell out of the dizzy cap,rotor resistor is popped or broken leads can cause it
who cares who wins
pass the pork pies
RobBrown
posted on 25/8/12 at 06:56 PM Reply With Quote
Cleaned everything and dried with kitchen towel and hairdryer. It must have been due to moisture as it has now stopped "tracking".
Mark Allanson
posted on 25/8/12 at 07:03 PM Reply With Quote
A coil designed for use with a ballast resistor being used where no ballast resistor is present?
RobBrown
posted on 25/8/12 at 07:17 PM Reply With Quote
Before I dried it all I was also thinking that myself. Everything was as it was in the original Sierra, but that's not to say it was right their either.
How do I tell. What does a ballast resister look like and where does it go?
I know my new coil is for a 1.5ohm ballast resister, but not sure about the original one?
Rob
