theconrodkid
| posted on 26/9/12 at 07:37 PM |
sat nav help !
turned on my trusty sat nav this morning,it,s a cheap chinese copy running "igo",a message appeared saying "programe application
database not found",tried reset and removing the chip but still the same,is it toast ?
who cares who wins
pass the pork pies
austin man
| posted on 26/9/12 at 08:13 PM |
Friend of mine had the same it was the sd card that was the problem. the sat nav had to be reprogrammesd to find the root menu. I copied the SD card
contents to my laptop, uploaded to a new car then configured it to select the exe file from the sat nav
theconrodkid
| posted on 26/9/12 at 08:43 PM |
i thought about the card,it,s a teeny weenie one so dont have a reader for it.
pluged it into my compo using a usb lead and it said unit was faulty so couldnt see what was going on .
cheers for the reply anyhow
who cares who wins
pass the pork pies
austin man
| posted on 26/9/12 at 08:57 PM |
try it in your phone then connect a lead to see if you can read it my mates was a standard sd one
mcerd1
| posted on 27/9/12 at 08:41 AM |
I assume its a microSD ?
if so you could use your phone as a card reader (assuming you've not got an iphone etc...)
or you can buy adapters to make them fit a normal SD slot:
linky
(half the time you get the adapter free with a new card)
or I got one of these:
linky free with a
card once, wish I still had it as its really handy
