russbost
| posted on 12/11/12 at 12:12 PM |
Activated Carbon in cooker hood filters
I'm sure someone on here must know, are the activated carbon or activated charcoal granules which are in cooker hood filters to remove smells on
recirculating air the same as activated carbon granules which are used in fish tanks?
MakeEverything
| posted on 12/11/12 at 12:21 PM |
carbon filters in extract recirc hoods are panel type, not granules. They are designed to remove grease and smells as opposed to being submersible.
(if thats what you meant).
Kindest Regards,
Richard.
Jon Ison
Yes, we sell tons in our eBay store (well tons may be an exaggeration)
item number 400230953151
MakeEverything
| posted on 12/11/12 at 12:22 PM |
Ha! Never seen granules in a cooker hood before. How do you use them?
Kindest Regards,
Richard.
Jon Ison
| posted on 12/11/12 at 12:25 PM |
Not quite correct, the carbon is there to remove steam and smells, it does not catch the grease, grease is its number one enemy, the paper or
aluminium filter is there to do that, carbon "panel" filters or cloth's are next to useless, the only ones that work well contain
activated chips, if your carbon filter does not rattle then it wont work very well.
Jon Ison
| posted on 12/11/12 at 12:30 PM |
If your venting outside you don't need them, they fit normally onto the motor/fan unit itself, removing steam and smells before the air is put
back into the room. The grease filter is the 1st filter the air passes through, normally paper or on better quality hoods aluminium gauze which can be
washed.
russbost
| posted on 12/11/12 at 12:34 PM |
Yeah, these are loose granules in a plastic housing, they try to sell you the whole thing for about a tenner a pop (there are 2 of them) but they can
be dismantled & the granules changed (proper locost solution!) I just wondered whether the fish tank ones were any different as there seems to be
quite a difference in price???
| posted on 12/11/12 at 12:42 PM |
ditto that cooker hoods do use the granular type. It doesnt come with the extractor as standard, you need to buy the part seperate. No idea on the
fish granules though.
snapper
| posted on 12/11/12 at 01:06 PM |
My cooker hood has the flat panel fibre filter in the main cover and activated granuals around the extractor fan housing
When I last packed it, it was very dusty, I would expect your tank water to black if you used the same stuff
I eat to survive
I drink to forget
Jon Ison
| posted on 12/11/12 at 01:35 PM |
Bit like a cosworth side entry dizzy cap or a pug 205 one, look (are) the same vastly different price.
russbost
| posted on 12/11/12 at 02:19 PM |
Thanx for all the info guys!
| posted on 12/11/12 at 02:23 PM |
The granules are also in water filter cartridges for caravan systems and Brita jug filters.
Bare
| posted on 12/11/12 at 04:37 PM |
Ermm.. Reroute your Stoves' extractor fan OUTDOORS ??.
The Filter type fan contraptions are just Laughable bodges.
Suck the fumes off the pots/pans and onto your face.. What could be finer??
Illegal in my part of the world if attempted over a Gas stove..
russbost
| posted on 12/11/12 at 05:50 PM |
It's over an induction hob & certainly hasn't presented any smell issues so far, presumably that's what the carbon is for? It
routes out near the ceiling, so nownere near the user
