Author: Subject: Bore clearence in plastic
tegwin
posted on 17/11/12 at 12:06 PM Reply With Quote
Struggling to find a decent source of info on this...
I am designing a compressed air powered motor to be machined entirely out of plastic. The bore is 18mm. If I want a reasonable seal on the piston but not too much friction what size should I make the piston? Was thinking something like a 0.05mm gap between the piston and the bore?
Any thoughts?
www.verticalhorizonsmedia.tv
RichardK
posted on 17/11/12 at 12:15 PM Reply With Quote
Dunno about an answer but could this be controlled easier with a groove in the piston and 'O' rings and trying different sizes?
Just a thought.
Rich
Gallery updated 11/01/2011
posted on 17/11/12 at 12:21 PM Reply With Quote
Small compressed air motors are generally vane type..
tegwin
posted on 17/11/12 at 12:24 PM Reply With Quote
Yup, I know that.
Trying to make a scale (ish) radial engine to run on compressed air..
More of an experiment to see how good rapid prototyped parts are..
Might just make them exactly the same size and polish the parts until they fit...hmmm
[Edited on 17/11/12 by tegwin]
coyoteboy
posted on 17/11/12 at 01:00 PM Reply With Quote
How fast is it going to turn and any lube? Put a small groove or two in the skirt on load it with oil.
Seems like a reasonable starting point but you may find it a bit tight. What's the manufacturing tolerances on the part?
tegwin
posted on 17/11/12 at 01:04 PM Reply With Quote
I actually don't know the manufacturing tolerances.... That would be useful to know... I also am not 100% sure of the surface finish either...so I think making it tighter than it needs to be would make sense...then polish until I get a good fit.
Bare
posted on 17/11/12 at 05:27 PM Reply With Quote
Try and find a used 'Air Hogs' toy. Those had plastic compressed air motors. Use it as a reference/study piece.
posted on 17/11/12 at 08:21 PM Reply With Quote
The real problem is making valve gear on a reciprocating compressed air motor compact enough.
tegwin
posted on 17/11/12 at 11:01 PM Reply With Quote
Ahah, I have come across a very simple rotary sliding valve. Will post some photos of it in a few days.
scudderfish
posted on 18/11/12 at 07:26 AM Reply With Quote
How about something like this?
http://www.animatedengines.com/co2.html
PSpirine
posted on 18/11/12 at 08:30 AM Reply With Quote
Don't know how you're planning on rapid prototyping them, but I very much doubt SLS or SLA will give you a smooth enough finish for the bore (unless you've got access to an F1 team..)
We've got some pretty fancy equipment at work but even that for a a piston bore I fear would cause the whole thing to bind to the point where it won't run due to the surface roughness. You can always sand it smooth of course
Make it relatively loose and just feed oil/lubricant to it?
phelpsa
posted on 18/11/12 at 09:40 AM Reply With Quote
Surfaces tend to grow on most types of RP. The problem being that this can be anywhere from 0-0.1mm depending on shape, location, size etc. seriously limiting your tolerances.
Your best bet would be making them the same size then machining them to your required tolerance.
