Xtreme Kermit
| posted on 19/11/12 at 08:56 PM |
Halfrauds - What's a cotter pin?
I must be getting old...
Thinking that you get spare bit for bikes in Halfrauds, I went in to get a set of cotter pins for an old bicycle my daughter uses.
Me: Hi, do you have any cotter pins?
Spotty pre-pubescent assistant: What are those then?
Me: They used to hold the pedals on in the seventies...
Spotty pre-pubescent assistant: Oh. We don't keep part for old bikes.
Whats a cotter pin??? . Arse!
bi22le
| posted on 19/11/12 at 09:02 PM |
Sorry, I dont know what a cotter pin is either. . . .
Please read my ring story:
AdrianH
| posted on 19/11/12 at 09:04 PM |
Spilt pin!
Adrian
Why do I have to make the tools to finish the job? More time then money.
big_wasa
| posted on 19/11/12 at 09:07 PM |
horrid things, I never could get them out.
[Edited on 19/11/12 by big_wasa]
coyoteboy
| posted on 19/11/12 at 09:10 PM |
That's not a cotter pin wasa? That's a tapered axle (still exist, though usually square taper).
This is a cotter pin:
mark chandler
| posted on 19/11/12 at 09:11 PM |
I would call a split pin a split pin, a cotter pin is the thing with an angled shaved edge that pins the pedal arms to the crank.
But then I am old, how do they secure pedal arms to cranks these days?
Big_wasa' pic
[Edited on 19/11/12 by mark chandler]
ReMan
| posted on 19/11/12 at 09:16 PM |
Yep and I used to wear them out being erm "heavy' on my bikes before BMX's were even thought of!
www.plusnine.co.uk
hillbillyracer
| posted on 19/11/12 at 09:18 PM |
Cotter pins are the tapered pins that hold cranks to old bikes & kingpins into axle ends on old vehicles, if they dont go in the first couple of
sharp knocks with a hammer they'll be a right cnut!
A split pin is a split pin.
coyoteboy
Current method:
Cotter pin:
http://en.wikipedia.org/wiki/Cotter_pin
I've apparently always known the US version
[Edited on 19/11/12 by coyoteboy]
mookaloid
| posted on 19/11/12 at 09:21 PM |
British Cotter Pin
American Cotter Pin - split pin in English
big_wasa
| posted on 19/11/12 at 09:22 PM |
Taken from wikipedia, so it must be true !
Cotter pin may refer to:
In U.S. usage:
Split pin, a metal fastener with two tines that are bent during installation used to fasten metal together, like with a staple or rivet
Hairpin cotter pin, more commonly known as an "R-clip"
Bowtie cotter pin, a vibration-proof type of R-clip that is shaped like a bowtie
Circle cotter, a ring-shaped cotter pin
In British usage:
Cotter (pin), in mechanical engineering a pin or wedge passing through a hole to fix parts tightly together
This usage difference is often a cause of confusion when companies of both countries work together.
beaten to it by mook
adithorp
| posted on 19/11/12 at 09:24 PM |
Wasa's picture IS a cotter pin.
A "split pin"as in the other picture, is actually really called a "split cotter pin" and something entirely different thing.
http://jpsc.org.uk/forum/
stevegough
| posted on 19/11/12 at 09:28 PM |
Big Wasa (and Mark Chandler) are right, Coyoteboy obviously works at Halfrauds
They are now secured by having a square, tapered bottom bracket shaft, with a matching square tapered hole in the pedal crank, the ends of the shaft
have a fine-pitch thread into which a bolt is screwed to retain the crank, this is recessed into the body of the pedal, then finished off with a
plastic cap.
See pic on the link --->
linky
The exception to this is BMXs which have a one-piece crank.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Ninehigh
| posted on 19/11/12 at 09:31 PM |
I was thinking a cotter pin was the one in the back wheel that allowed you to freewheel
Xtreme Kermit
| posted on 19/11/12 at 09:34 PM |
Yep, I'm with wasa on this. Its the taper jobby
Leave this nut on loosely and whack it with a club hammer. If yer lucky it'll come loose.
Looks like I'll have to try a proper bike shop, as I'm guessing the eBay ones will be made of chocolate...
Interesting about the American connection. Never expected that.
adithorp
| posted on 19/11/12 at 10:08 PM |
The trick to removing is to hit the other end first. Counter-intuitive but it works.
Canada EH!
| posted on 19/11/12 at 10:12 PM |
From the Colonies, a split pin in North America is called a cotter pin. The metal retainer which holds the axle nut from unwinding and falling off the
spindle closely fallowed by the front wheel.
ChrisL
| posted on 19/11/12 at 10:14 PM |
I was in there out of desperation on sunday after brake bleed nipples for an MX5, 'huh' was my response
austin man
| posted on 19/11/12 at 11:07 PM |
definitely the tapered one a split pin is as it says a pin that splits usaully used through a castleated nut fitted many of these on Raleigh choppers
oh and on the bottom of the Austin a35 Kingpins
Andi
| posted on 19/11/12 at 11:15 PM |
I was asked what a Sierra was last year at my local Halfords.
| posted on 19/11/12 at 11:23 PM |
A different type of cotter pin used to hold the handbrake cable into the lever on back axles. It was like a nail with a hole drilled in for a split
pin to go through.
Westy1994
| posted on 19/11/12 at 11:27 PM |
Yes I remember Cotter Pins, I used to stock up on them back in my cycling years, but your story reminded me of another example of stupidity with
todays shop staff. About 15 years ago, when I was Hillclimbing, I took a brand new set of Yoko slicks and some wheels to Kwickfit, I was stood there a
good 20 mins before getting the attention of someone, despite them knowing I was there. After a while I had to go over to a guy after someone wwho had
just walked in got their problem sorted out in seconds, the guy said " I am not putting those tyres on those wheels because they are totally
bald"....... I kid you not they were the words he used.... I said I know they are bald, I paid dam good money for them to be such.... This
confused him somewhat, and went to fetch his boss..... Who apologised and gave me a discount for the wasted time and ignorant staff...
The lad wasn't there a week after that.....
indykid
| posted on 20/11/12 at 12:10 AM |
You'll be lucky to find m8x1 bleed nipples even in a good motor factor's. I had to get mine from brakes international.
Ninehigh
| posted on 20/11/12 at 07:19 AM |
Probably thought you were some sort of pervert after hearing "break bleed nipple"
liam.mccaffrey
| posted on 20/11/12 at 07:36 AM |
I've had real trouble finding bleed nipples locally. I did manage to find a lorry mechanic who had a big stash though.
Build Blog
Build Photo Album
