bi22le
| posted on 12/12/12 at 01:28 PM |
OT(well its 12V): Controlling 200W motor 12V
Hi all, not strictly car related but is kind off. . . .
Anyway. I have a 200W motor that I need to vary the speed on. 200W @ 12V means that its pulling around 17A which is well beyond the basic
potentiometers or potential divider circuits.
I dont want to go into complex timing or PWM circuits, I just want to dial in a speed!
Is it an OP Amp and controller circuit or am I over cooking this? Im the only person in my company that understands electronics but 200W is beyond my
comfort zone!
Biz
Please read my ring story:
v8kid
| posted on 12/12/12 at 01:31 PM |
Get one of the cheap chinese electric bicycle controllers off ebay and save the hastle
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
Rod Ends
| posted on 12/12/12 at 01:35 PM |
Reversible 200W DC Motor Speed Control PWM Controller
Myke 2463
| posted on 12/12/12 at 01:41 PM |
The MK1 mini had a big potentiometer for the heater fan. item no 390381086518 brand new from Lucas.
Adjustable Heater Switch (Rheostat) for Austin Morris Mini Mk1 1/4t Van 1959-67
Be Lucky Mike.
Confused but excited.
| posted on 12/12/12 at 03:25 PM |
I'll go and have a look in the garage, I may have what you want. It's a small control board that I made ages ago to control the speed of a
fairly beefy d.c. motor, used to spin a quite heavy lighting unit.
Potential divider networks up to 3Kw are quite cheap. They are called fan heaters.
[Edited on 12/12/12 by Confused but excited.]
| posted on 12/12/12 at 03:34 PM |
Found it!
It has a TIP 34C output stage and if memory serves, it will only handle a max O/P of 15A the circuit is quite simple and if you are OK with simple
electronics, it shouldn't be too hard to beef up the O/P stage.
If you want to U2U me your mobile no I will send you a photo.
If it's any good to you, you are welcome to it. I made it in 1986.
Bare
| posted on 12/12/12 at 04:27 PM |
Fill your Boots :-)
http://www.hobbyking.com/hobbyking/store/__9090__Turnigy_20A_BRUSHED_ESC.html
bi22le
| posted on 12/12/12 at 05:00 PM |
Thanks for all of your help guts. Still LCB comes up trumps.
Confused - Replied to your U2U.
| posted on 12/12/12 at 05:40 PM |
I was also going to suggest a brushed r/c ESC with a $2 servo tester attached to it
