Author: Subject: Garage floor problem
clairetoo
posted on 29/12/12 at 04:38 PM Reply With Quote
I had a `builder' put down the base when I put up my concrete sectional garage to use as my machine shop , and I've had a major damp problem ever since .
With all the heavy rain we've had the last few weeks its been flooded , with up to 2" of water over most of the floor (as well as damp , its not very flat either....)
So.......today I smashed a hole in the middle of the floor , to see what was going on . The `builder' had put polystyrene insulation under the concrete (which seems to be 90% gravel) , but on top of the damp proof membrane !
That cant be right ?
I dug down about a foot , and dropped in a garden water feature pump , set on as low as it will go , and have been pumping water out all day - the water is dripping off the top of the DPM...........
Any ideas how to fix this ? The layer of insulation (which I didnt want.....) is water-logged , and from what I can see of the edge of the slab , the DPM is turned up at the edges , so what I have is a pond.......when what I need is a dry workshop.......
Its cuz I is blond , innit
Claire xx
Will weld for food......
r1_pete
posted on 29/12/12 at 05:59 PM Reply With Quote
Hi Claire.
It sounds as though the surface of your garage floor is below the surrounding ground level, or, you have a lip of floor around the outside of the garage which is catching water and channeling it inside.
If it is the latter, you could try masticking up between the bottom of the walls and floor and between the panels, on the inside, then create a 30 degree plus ramp around the outside in concrete to channel the water away.
If it is the former, the only real solution is to start again and build the floor up higher than the surrounding ground, if you are not short of headroom you could try building up the floor inside only, but the proper solution is too start again, and make sure any dpc is above surrounding ground level, otherwise, as you say you are building a pond.
[Edited on 29/12/12 by r1_pete]
samjc
posted on 29/12/12 at 06:26 PM Reply With Quote
If you intend to use the garage often and keep it for a few years, I would first build a concretlip on inside and out of all walls (obviulsy avoiding doors) to try seal the garage, and then I would try fitting some cheap drainage like the thin grating you put infront of the garage door. I myself have the same issue and also have a small ramp inside both doors to seal it all once doors are closed, if picture are required u2u me your email adress and ill send you pictures.
macc man
posted on 29/12/12 at 06:41 PM Reply With Quote
A freind of mine had the same problem with a garage installed by 'professional installers'. I went around the outside and inside walls with silicone mastic. Best to use the type you can use under water. Then I haunched up inside and out around the walls with a fine concrete mix with waterproofing added. This made a huge difference and kept the water out. Worth a try before starting again.
posted on 29/12/12 at 08:02 PM Reply With Quote
Sounds like he's done the slab like you would for a house, but too low (obviously for a garage the finished level needs to be close to ground level). He's not thought it through!
Now you have cut through the damp membrane, you will get water seeping up through it if you just fill the hole and concrete. You can dig round outside and try to create some drainage to stop it coming in under the wall sections.
The floor insulation does seem pointless since the room will be largely unheated. FWIW, house builders are free to put the insulation over or under the conrete at will. Having it under the slab means you have more thermal mass in the house so a more stable temp.
SteveWalker
posted on 29/12/12 at 08:08 PM Reply With Quote
It's perfectly normal to put polystyrene on top of the DPM - our conservatory floor is done this way. In fact, in this case the insulation had to be above the DPM, as clips needed to be pushed into the insulation to hold underfloor heating pipes in place while the screed was poured on top.
The DPM being turned up at the edges is also correct, as the DPM is probably below ground level and so has to prevent water penetrating from the sides as well as below. If you are getting damp problems it is likely that water is getting in around the edges, but above the DPM (possibly under the walls) or that the DPM was damaged when it was put down (it should have been laid on top of a sand blinding to prevent the membrane being punctured by the hardcore below).
loggyboy
It is unlikely to be insulation, more likely to be something like Claymaster: http://www.bbacerts.co.uk/CertificateFiles/25/2543ps1i1a18.08.2011.pdf
Mistral Motorsport
clairetoo
posted on 29/12/12 at 08:32 PM Reply With Quote
Nope....its just ordinary polystyrene sheet......which is totally waterlogged
I've noticed for a long time that after rain , water literally rises up through the floor - so the concrete is allso permanently wet (in last winters megga low temperatures several patches of the floor `exploded' as that water froze and expanded)
I've pretty much resigned myself to digging a soak-away drain across the rear of the garage where the garden is quite a bit higher , the hole in the floor I will dig as deep as I can and just fill it with suitable gravel (pebbles ?) , then just make a grate to cover it .
I suppose long term I would be best to add a new membrane and 2" of fresh concrete on top - but theres two lathes , a small milling machine and compressor in there........plus a bit of junk
Claire xx
jossey
posted on 29/12/12 at 09:22 PM Reply With Quote
Membrane from floor across to the walls n up a ft then concrete over the membrane put drainage under that though first.
David Johnson
posted on 29/12/12 at 10:00 PM Reply With Quote
My garage has the same problem, that the land at the back is far too high. I dug it out once but its difficult to get to and didnt really help, since the sides are paved and i couldnt put drainage in! There is no substitute for doing it right first time.
bi22le
posted on 30/12/12 at 03:30 AM Reply With Quote
If dpm is in place your pond is being filled from the top. Either find where the ingress is and seal it or make a soak away.
Soak away can just be a 500mm X 500mm hole at the lowest point. Drive piles into the ground of any dia and side tubes down that are perforated. Fill the lot with course sand or gravel.
Depending on garage size and knowing your skills i would do this.
I hope you live above the ground water level.
Please read my ring story:
wylliezx9r
posted on 30/12/12 at 08:41 AM Reply With Quote
iHi claire,
My garage has internal concrete edging as shown in the picture below. I often have water pooling around the outside perimeter but the floor inside stays bone dry. If your garage doesnt already have this I would do this first before doing anything major (I dont know if it's a special type of concrete ?). I would say that your base has been put down correctly althought I dont know what the purpose of the insulation is in a garage.
HTH Dan
[Edited on 30/12/12 by wylliezx9r]
George Best
splitrivet
posted on 30/12/12 at 10:31 AM Reply With Quote
How about digging a trench all the way round with a land drain covered with gravel brought round to a sump and pumped or led to the nearest drain. Google French drain to see what I mean.
Bob
[Edited on 30/12/12 by splitrivet]
