ReMan
| posted on 18/1/13 at 08:49 PM |
UPVC DOOR Lock unit questio?
Anyone here in the trade on this?
The front door lock set on My daughters new house hais worn out and needs replacing.
I've done both my own before so I know a bit about how to do them nd what to measure.
The one one it is a Ferco stamped 025.
its also got a slightly doglegged/raised faceplate like ______/--------\_____
Its a 70mm unit the 025 suggests 25mm backset, but
Problem is I cant find an equivalent, or any info on this, so wondered if any ones got experience or an old catalogue that helps?
Ta
www.plusnine.co.uk
Mark2
| posted on 18/1/13 at 09:05 PM |
Hi
Try these people, used them before and have usually come up trumps.....
http://www.upvc-hardware.co.uk/
Cheers Mark
https://www.facebook.com/WestfieldSportsCarClubWirralNorthWales?ref=hl
austin man
| posted on 18/1/13 at 09:07 PM |
The thing to check for is the offset measure from where the screw is in both directions as the hole is not normally central in the lock. Hope that
makes sense
Rod Ends
posted on 18/1/13 at 09:24 PM |
Used these before - they have diagrams of locks.
www.locksonline.co.uk/acatalog/UPVC-Door-Locks.html
ReMan
| posted on 18/1/13 at 09:47 PM |
Chhers guys .
Never had this trouble before, everything is on the web, but this one as a starnge one.
I think I might have to speajk to a real person
www.plusnine.co.uk
austin man
| posted on 18/1/13 at 10:00 PM |
cant you post a photo it will make it easier
any of these I initially thought you where after a barrel lock
http://www.ebay.co.uk/sch/i.html?_trksid=p3984.m570.l1313&_nkw=ferco+lock&_sacat=0&_from=R40
[Edited on 18/1/13 by austin man]
wicket
| posted on 19/1/13 at 07:56 AM |
Had a similar problem matching Ferco parts, got mine from here
https://www.upvc-hardware.co.uk
Ben_Copeland
| posted on 19/1/13 at 10:07 AM |
Talk to the manufacture if you can. I had trouble with our conservatory lock, they replaced it free of charge.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
ReMan
| posted on 19/1/13 at 11:13 AM |
Heres the offender.
As can be seen it has a unusual raised part that I cant find on any sites. As said I'll try and make a call or two
  doorlock1
  uplok
www.plusnine.co.uk
Dinoguin
| posted on 1/3/13 at 03:00 PM |
Hi, did you manage to sort this lock out? I am going through the same thing at the moment trying to find a Ferco 025 lock and I am having no luck.
I'm that desperate to find one that I have just registered on here so I could ask you lol.
Matt
| posted on 19/4/13 at 01:50 PM |
Try and measure the PZ of the door handle by following the diagram here: http://upvcspareparts.co.uk/pz-door-handle-measuring-diagram/
After you know that you should find it a lot easier to find a suitable replacement door handle:
http://www.upvcspares4repairs.co.uk/upvc-door-handles
Chances are the door handle you have now will not be manufactured any more, however its usually possible to get a suitable replacement if you measure
the existing door handle correctly.
[Edited on 19/4/13 by Matt]
Ben_Copeland
| posted on 19/4/13 at 02:56 PM |
Well I hope he's fixed it after 3 months!!
[Edited on 19/4/13 by Ben_Copeland]
Ben
Roadster
ReMan
| posted on 19/4/13 at 05:29 PM |
Ooops
I missed this, I think it was when the site was broken and no emails sent.
Yes I did fix it. Thanks to everyone that assisted
This fitted straifght in, just be double sure of the number of rollers as mine was not 4 roller after all it was 2 roler and two mushroom, but lock
bit is the same
Details:
Here's a link to the lock on our website:
https://www.upvc-hardware.co.uk/locks-gearing/multipoint-upvc-door-locks/ferco-upvc-door-locks/ferco-4-roller-multipoint-upvc-door-lock
However your lock is 25mm backset, the closest available now is 28mm backset. It's basically the same lock without the raised section in the
middle of the faceplate. When fitting the 28mm it may just stand proud by 3mm near the centre of the strip.
Kind Regards
Chris
UPVC Hardware
On 01/02/2013 09:29, Colin wrote:
Hi
As per conversation earlier this week I attach a couple of pictures of this unusual lock.
It is definitely stamped FERCO 025.
It is a 4 roller
The backset appears to be ±25-28mm
The lock to handle is 70mm.
As can be seen the unusual bit is the raised section in the lock area.
I would be grateful if you can shine any light as to a suitable replacement
www.plusnine.co.uk
