Poll: soldering 15mm copper pipe [View Results]
1 solder with a heat gun
2 buy a gas blow torch
Author: Subject: soldering 15mm copper pipe
jacko
posted on 21/3/13 at 06:49 PM Reply With Quote
Westy1994
posted on 21/3/13 at 06:58 PM Reply With Quote
My voting was the only real answer i think, not entirely sure a heat gun would get the pipe hot enough to melt the solder - having said that I have never tried it......
posted on 21/3/13 at 07:25 PM Reply With Quote
Ditto, can't see a heat gun getting it hot enough.
jacko
posted on 21/3/13 at 07:31 PM Reply With Quote
engine  2
engine 2
The copper pipe on this engine was soldered by using a heat gun but thats not the heating in my home with floor boards naild down and carpet over the joints
Jacko
Slimy38
posted on 21/3/13 at 08:02 PM Reply With Quote
I bought one of these for my brother in law, in exchange for him plumbing my bathroom;
ROTHENBERGER GAS SOLDERING IRON SOLDER BLOW TORCH 1950 °C NEW | eBay
It worked fine for the whole job.
posted on 21/3/13 at 08:19 PM Reply With Quote
Whichever method you use, you'll probably find one of these invaluable;
eBay Item
Phil
posted on 21/3/13 at 10:43 PM Reply With Quote
Do it properly. Gas torch, heat map, wire wool, flux, lead free solder. Get it hot enough to melt the solder but not burn off the flux, don't apply the heat whilst melting the solder, don't apply too much solder, quick wipe around the pipe to leave a nice fillet and don't touch it till it's cooled down. And get a pipe bender and make nice gentle corners rather than using 90 degree solders which will leave noise. And don't forget expansion on long runs so make the pipe a Z shape.
wilkingj
posted on 22/3/13 at 03:33 PM Reply With Quote
+1
Best Regards
Geoff
http://www.v8viento.co.uk
