Author: Subject: Building Regulations
austin man
posted on 14/4/13 at 09:35 PM Reply With Quote
Hope someone on here can give me a bit of advice , I live in a Terraced house no access to the rear by road so unable to have a garage to the rear.
I understand that there have been some changes to the building regs lately and was wondering if I would be able to have a garage built to the front elevation of my house if so the garage would have to be attached to the house due to the size of the fromt garden.
Cany anyone offer me advice or the best place to find out what is permittable under the regs
Benzo
posted on 14/4/13 at 09:51 PM Reply With Quote
Im an Architect and i would see you having 3 issues -
- The road service granting easment over the footpath to enter the garage door.
- Building regs for Fire safety between a garage and habitable space.
- Planning laws where you will be changing the style of the street.
Not to mention what is will do to the living spaces of the house in terms of lighting.
austin man
posted on 14/4/13 at 10:01 PM Reply With Quote
Looks like I will be better erecting a carport or something similar then , the right to light scenario shouldnt be a real problem as we have sunlight on the back garden from 7,30 am and shade on the front all day long. an up an over door would possibly affect pedestrians.
If I went for a carport could sides be used ie similar to a curtain side trailor, just getting fed up with the car sitting outside over winter under a cover
Benzo
posted on 14/4/13 at 10:04 PM Reply With Quote
It not the door and pedestrians, its the driving on the footpath part, they roads service would never accept a drop kerb etc infront of the garage door unless some of your neighbours already park in their front garden area and have there fore set a precedent?
Not really talking about other peoples right to light either, its more how dark is would make the living conditions in your own house.
Benzo
posted on 14/4/13 at 10:06 PM Reply With Quote
on the carport idea too, its possibly more feasible, if it was made from timber could be seen as a temporary structure and would not require planning what so ever.
austin man
posted on 14/4/13 at 10:14 PM Reply With Quote
my neighbour an I already have a dropped kerb the council did this when they relaid the footpaths, both my neighbour and I park on a concreste drivevay in front of the house and have done so for years. Kerbs where dropped around 7 years ago
[Edited on 14/4/13 by austin man]
Benzo
posted on 14/4/13 at 10:20 PM Reply With Quote
Thats a good start then that you already park at the front of the house.
Do you want to lodge for planning for is or are just thinking about just going for it? you really have 2 x option temp. structure and no planning or a masonry garage with planning permission.
If you wanted to loose you living room and just extend out slightly you could maybe do it under permitted development. 10% of the existing floor area as far as i am aware (N.Ireland regs).
[Edited on 14/4/13 by Benzo]
austin man
posted on 14/4/13 at 10:35 PM Reply With Quote
Ideally I would love a garage I have lived in this house for 24 years now and spent too many cold days working outside but if my only option is a temporary structure I would have to go for that . I would plan to have a brick built structure to match the existing brickwork If I where to go the garage route
Benzo
posted on 14/4/13 at 10:45 PM Reply With Quote
Well if you want to go for a built extension the you'll need to consult an architect, architectural technician or planning consultant to have it all done above board. I'd prob go with the latter 2 as the fees will be less.
morcus
posted on 14/4/13 at 11:54 PM Reply With Quote
Would the rules be different if you built a shed instead? Just one with a massive door.
snapper
posted on 15/4/13 at 05:12 AM Reply With Quote
Having demolished my garage to build an extension to the living space I first opted to rent a lockup garage, kept the car dry but no power or light and limited space
I know rent a barn with 2 others, loads of space for only a little more than a lockup and we have power and light
I eat to survive
I drink to forget
posted on 15/4/13 at 07:01 AM Reply With Quote
Highly unlikely you'd be allowed to build forward of your house, they draw an imaginary line along the frontages, call it the building line, and dont allow anyone through it. This is for the planning department rather than building control who enforce how it is built.
A lot of people say that timber structures are temporary and dont need planning, but im not sure this is the case really.
Not Anumber
posted on 15/4/13 at 08:54 AM Reply With Quote
I've been thinking about the same for some while. Using the 'temporary structure' excemption to build a garage on part of my drive, effectively putting walls and a roof over part of the drive between the house and the pavement. I have a full width dropped kerb. It wouldn't block the windows of the house as most of it's width would be in front of a covered sideway (narrow garage type space between me and the neighbour's house).
I'd be interested to know what sort of build I could get away with as a temporary structure and whether it would be acceptable to have the doors opening onto the pavement ?
Benzo
It depends how it's built etc. It's the only real option and then hope that the planners don't enforce it.
RedAvon
posted on 15/4/13 at 11:01 AM Reply With Quote
I've taken a few commercial and personal projects successfully through planning/building control and would recommend approaching the planners direct.
I would make an appointment or pop in to your local planning department with a very basic sketch/idea of what you wish to do and ask them for a few minutes to discuss your proposals/plans. I've found this initial dialogue breaks down the formal barriers and helps you understand what they are likely to allow before spending any of your time or money.
Once the dialogue has started I've also found that if I couldn't do exactly what I want - which is usual - they are willing to consider other ideas, options and even make suggestions for what they will accept (in broad terms with no commitment).
Your local office may not be as helpful but its certainly worked for me with large and small projects.
Hope this helps.
Ian
puma931
posted on 15/4/13 at 11:15 AM Reply With Quote
I don't want to hi-jack this but, Benzo could you advise on:
Do I need planning permission to turn an integral garage into a room?
And
Do I need permission to build a detached single garage at the front of the drive that borders a road?
Mathew
[Edited on 15/4/13 by puma931]
Benzo
posted on 15/4/13 at 11:17 AM Reply With Quote
Hope this helps.
Ian
Very good point, it would be a good idea to take an OS map, Photocopy it and sketch out to scale what it is that you are thinking about before entering into a fee agreement.
Benzo
posted on 15/4/13 at 11:22 AM Reply With Quote
And
Mathew
Mathew,
You will without doubt need planning permission to build the garage and consent from road service to access onto the road, if you already have a drop kerb in front of your house and park in the driveway things will be more simple.
Generally you will not need planning to convert your existing garage, but you need to be sure that the garage is built to a standard that will be habitable, insulated roof, walls etc. Personally i would go ahead with the conversion and fingers crossed it will not be enforced. Planning laws here in NI mean that if a building is not enforced with in 7years of it being done then it is beyond enforcement. So, keep your neighbours sweet.
*edit - Only just seen the photo, where do you want to put the garage? in front of the existing garage? detached?
[Edited on 15/4/13 by Benzo]
puma931
posted on 15/4/13 at 11:56 AM Reply With Quote
Hi, Yes, would like to put a detached garage in front of the existing one, but boardering the road (all drop kerbed) with a side entry/exit.
Thanks.
And
Mathew
Mathew,
Benzo
posted on 15/4/13 at 12:05 PM Reply With Quote
It cannot be too close to the road as to block you access viability, that will be determined by the speed of the road you live on.
How would that effect the light coming into the space you want to convert the existing garage too?
You will need to liaise with your planning authority like mentioned above. Do any of your neighbours have anything similar to what you want to achieve? if so you can use them as precedent and expect the same providing policy hasnt changed since it has been granted for them.
posted on 15/4/13 at 06:52 PM Reply With Quote
Would you have room to pull out of your garage and close the door without crossing your property boundary ? If not you may not get planning, that's how it works round here anyway.
