Author: Subject: Marker pen removal
swanny
posted on 28/5/13 at 05:01 PM Reply With Quote
Marker pen removal
Hello all,
Our two year old has decided the draw all over our sofa in black marker pen, it wasnt a permanent marker as it came with a 'wipe ckean' book. Have had a couple if goes at washing with vanish etc but its not shifting. Any clever ideas from the locostbuilders collective brain?
At
Paul
morcus
posted on 28/5/13 at 05:05 PM Reply With Quote
What is the sofa made of?
doobrychat
posted on 28/5/13 at 05:42 PM Reply With Quote
brake cleaner is good if its cloth... gets all sorts of stains out of my jeans...
sarky comments welcome........
TimC
posted on 28/5/13 at 05:44 PM Reply With Quote
Acetone maybe? Try it underneath first to check it doesn't cause further havoc.
jossey
posted on 28/5/13 at 05:52 PM Reply With Quote
Plus 1 for brake cleaner
David Johnson
zetec
posted on 28/5/13 at 06:05 PM Reply With Quote
Lighter fluid (zippo lighter fuel) is also very good at stain and oil based marks.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
flak monkey
posted on 28/5/13 at 06:43 PM Reply With Quote
Spray deoderant... not anti-perspirant.
mazie
posted on 28/5/13 at 06:49 PM Reply With Quote
2nd the zippo! Have the same mark to shift to the cream headlining off the other halfs car although that was her fault!
posted on 28/5/13 at 07:08 PM Reply With Quote
Brake cleaner!
posted on 28/5/13 at 07:35 PM Reply With Quote
Aftershave definitely works on leather, I had the same problem. It's also a nice harmless product to begin with.
scudderfish
posted on 28/5/13 at 08:31 PM Reply With Quote
Baby wipes?
swanny
posted on 28/5/13 at 09:22 PM Reply With Quote
Nothing seems to shift it, tried lighter fluid, alcohol gel, baby wipes, Even had the hand steamer on one section but it did very little. According to the Internet dry wipe markers are very hard to shift.
posted on 28/5/13 at 09:33 PM Reply With Quote
aftershave?
Aaron_n_Sim
posted on 28/5/13 at 09:38 PM Reply With Quote
I second acetone! my missus's nail varnish remover gets rid of marker pen on all breaker bought parts, sharpies and just about anything I use!
Work to Live don't Live to Work
coyoteboy
posted on 29/5/13 at 12:37 AM Reply With Quote
IPA? Deoderant worked on my paintwork but not sure it will help on a sofa.
https://www.fixmystreet.com/
DarrenW
posted on 29/5/13 at 06:04 AM Reply With Quote
Don't go mad on various garage solvents until you have tried bicarbonate of soda. Obviously test in an inconspicuous place first.
I used it to remove blood from a cream rug recently, unbelievably good. Strong mix with water, applied locally with a cloth, allowed to soak for a minute.
T66
posted on 29/5/13 at 06:21 AM Reply With Quote
I write on acetate with permanent marker, to remove it I use a non permanent pen and scribble over it, which loosens it, then I wipe it off.
Please take plenty pictures for use at their 21st birthday party, good luck
matt_gsxr
posted on 29/5/13 at 08:49 AM Reply With Quote
wd40?
coyoteboy
posted on 29/5/13 at 12:18 PM Reply With Quote
Did the rug roll out flat again after?
CompoSimmonite
posted on 2/6/13 at 08:28 AM Reply With Quote
Originally posted by scudderfish
Baby wipes?
Baby wipes are good for cleaning car upholstery (I didn't believe it myself until I tried !) so get my vote as well.
paul h
CompoSimmonite
posted on 2/6/13 at 08:30 AM Reply With Quote
Baby wipes?
If that doesen't work and it's a decent setee then contact your home contents insurer as they might be able to put you in touch with a professional cleaner to avoid having to pay out for a replacement.
paul h
jacko
posted on 2/6/13 at 03:23 PM Reply With Quote
WD 40 is good for removing glue so you never know it may remove ink as above try it first under the chair
spiderman
posted on 2/6/13 at 04:40 PM Reply With Quote
Should lay flat again once the body has been disposed of, always worked for me.
Spider
posted on 2/6/13 at 05:12 PM Reply With Quote
It was only rolled up for a brief trip to the canal
edsco
posted on 2/6/13 at 07:29 PM Reply With Quote
Never tried it.....but WD40 is supposed to work very well. However it might make your sofa smell like the garage ;-)
edsco
