Author: Subject: 12"x12" stainless steel square wanted ?
steve m
posted on 6/8/13 at 02:01 PM Reply With Quote
Hi Guys
300mm /12" x 300mm/ 12" x 2mm-4mm thick, stainless steel square wanted ?
must be flat and blemish free, but could be brushed finish
does anyone know of a supplier or any one able to cut such any item ?
regards
benchmark51
posted on 6/8/13 at 03:00 PM Reply With Quote
I don't what you want this for, but is it for stone guards?
If so, I bought some that are 29mm x 29mm and cut diagonally at the bottom(usual stone guard shape)
mirror finish 1 side
They are currently £7.50 inc each at kitspares
http://www.kitspares.co.uk/shop/item.php?cat=2&product=4727&catsub=7
steve m
posted on 6/8/13 at 03:34 PM Reply With Quote
Stone guards !!
NO, its for me to make a kitchen clock, that is why its 300mm x 300 mm as to fit in a perfect place
Plan is to drill a hole in the middle, and mount a clock mechanism in the hole, and stencil a black cross for 12-6 and 9-3
liam.mccaffrey
posted on 6/8/13 at 04:03 PM Reply With Quote
I'd almost guarantee you could get that as an offcut on ebay.
Build Blog
Build Photo Album
steve m
posted on 6/8/13 at 05:29 PM Reply With Quote
Thanks Liam,
Ive tried ebay, but not much luck yet
iank
posted on 6/8/13 at 05:52 PM Reply With Quote
907 might know a supplier who would do an off-cut.
Anonymous
NigeEss
posted on 6/8/13 at 09:03 PM Reply With Quote
2-4mm for a clock
mcerd1
posted on 7/8/13 at 07:36 AM Reply With Quote
try these guys: http://www.nogginend.com/
although at 2 - 4mm think I'd think your more likely to get a raw bit of metal to polish/brush yourself...
i've been getting on quite well with these things for all my little projects:
http://www.frost.co.uk/satinising-mops-6-inch-and-set.html
the fine one makes an nice job on alloy and the course one is quite good for steel, but its really a satin finish rather than a brushed finish
renetom
posted on 7/8/13 at 04:41 PM Reply With Quote
Hi Steve
I have a piece of St steel sheet 300X250 polished one side & brushed the other
You are welcome to it if its any use
René
ashg
posted on 7/8/13 at 05:07 PM Reply With Quote
have you tried
crawley metal services
elliot metals
colbridge Engineering
they are all local to you.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
steve m
posted on 7/8/13 at 06:03 PM Reply With Quote
Thanks Guys
Wifey has changed her mind AGAIN,
But Rene's piece could be what im after, and im passing yours tomorrow, as off to collect the caravan!
posted on 8/8/13 at 02:49 PM Reply With Quote
Quick calc shows that a 12"x12"x4mm lump of stainless will weigh about 3KG! You might want to get a rawl bolt so you can hang the clock safely
Could you perhaps laminate a thin sheet of stainless onto a some alloy plate (using e.g contact adhesive)? Would probably be cheaper as well as lighter.
mcerd1
posted on 8/8/13 at 03:42 PM Reply With Quote
I'd agree with your maths
304 stainless is about 7900 kg/m­³, 0.3048*0.3048*0.004*7900 = 2.936kg
but I think you'd be best laminating a thin sheet (say 0.5mm) onto a block of MDF
if you don't want to see the edges of the wood you could get a slightly bigger sheet of steel and fold the edges over - this way you get brushed steel edges that you wouldn't get with a solid plate
I got a 600x900mm sheet of 0.9mm brushed stainless of ebay for £25 delivered, thats almost enough for 6 clocks
Krismc
posted on 11/8/13 at 04:38 PM Reply With Quote
I can get you stainless steel delivered to ya door cut and finished in any pattern. Ill get a price in brushed for you but id estimate £15-20.
kris
