Author: Subject: House Alarm Problem
posted on 7/8/13 at 07:53 PM Reply With Quote
House Alarm Problem
Any alarm engineers on here?
I have a peculiar problem with mine, when I key in the number to set the alarm it goes through the beep beep beep 20 second exit bit then the internal alarm sounds.. keying the number back in stops this but the entry/exit led stays red to indicate a fault?
I've googled this but cant find anything specific.
Any help would be mucho appreciated.
YQUSTA
posted on 7/8/13 at 08:06 PM Reply With Quote
What system are you using and what type of sensor is the entry/exit?
"If in doubt flat out"
Colin McRae
omega 24 v6
posted on 7/8/13 at 08:07 PM Reply With Quote
I'm not an expert by any means but have done a few ( less than 10 ). From your description I'd say the entry/exit contacts are faulty or the wiring to them.
I'd imagine its either a pir sensor unit or magnetic contacts on the door. Most systems have a walk test function where you can see/hear the individual circuits working.If your entry/exit zone does not beep on the control panel when you walk test it ( pir) or open/shut the door ( magnetic contacts) then you need a new pir ( or check the wiring for continuity ) or a contact set ( again or check the wiring for continuity.
Hope this helps get you on your way.
posted on 7/8/13 at 08:15 PM Reply With Quote
Its PIR above the door. Asked the installer to put contacts on the door but I think cause its a brick wall he couldn't be bothered.
I've already identified the sensor on zone 6 is goosed so might just change them all.
Did a walk test, opened the back door and nought happened.. didnt go any further
Its a Scantronic 9448 btw
posted on 7/8/13 at 08:18 PM Reply With Quote
OK just done another walk test, the entry/exit led flashes red and the panel beeps loud and fast.
I'll get some new sensors and see how I get on.
YQUSTA
posted on 7/8/13 at 08:23 PM Reply With Quote
If its a PIR and you do a walk test you need to activate more than 1 of the beams it produces to activate it.
Just wave your hand in front of it is the easiest way.
do a walk test see what happens if the PIR does nothing just replace it.
Be aware if you dont know the engineer code the alarm will go off when you take the cover off the PIR as you will activate the tamper switch inside.
you should be able to enter your code to stop the alarm once you have removed the cover.
You could always swap the PIR on the entry/exit door to a contact if you would prefer, I prefer them on doors to be honest.
Edit, here is the installation/user guide should you need it.
Guide
[Edited on 7/8/13 by YQUSTA]
Colin McRae
posted on 7/8/13 at 08:32 PM Reply With Quote
Yes mate, got that guide, it takes a big wave in front of the PIR to get it to light up.
Problem is a soon as I entry the walk test the entry/exit red led is on and the panel makes a racket. Thats before I get to PIR!
Canada EH!
posted on 7/8/13 at 09:04 PM Reply With Quote
I don't know how they work with a 220 volt system, the ones here in Canada run on 12 volts DC, I work for an alarm
company. Are your sensors hard wired or battery powered?
YQUSTA
posted on 7/8/13 at 09:06 PM Reply With Quote
Sounds like the PIR is faulty then as it is activating without anything activating it.
swap it out and you should be back on track.
Colin McRae
posted on 7/8/13 at 09:17 PM Reply With Quote
They run off the board at 12v DC, Six wires, +12v and ground, two anti tamper, two for the sensor signal open/closed.
omega 24 v6
posted on 7/8/13 at 09:23 PM Reply With Quote
OK it looks like its seeing you but you need to confirn is it latching its relay on the contacts side
ETA scrap this message . Was out with the dog and thought I'd posted it before I left. Reading the last few posts i reckon you've got it sussed out now.
[Edited on 7/8/13 by omega 24 v6]
posted on 10/8/13 at 01:14 PM Reply With Quote
Thanks for all the help chaps, I've learned how it works now and found the PIR had a contact wire hanging out. Connected that and it works fine.
Now I've found the back door isnt working, some dude (the installer I reckon) has connected both contact wires to the same post...
I'm wondering now what other short cuts the lazy git has done..
YQUSTA
posted on 10/8/13 at 05:23 PM Reply With Quote
I would just go round all the detectors and check, won't take long and better safe than sorry.
Glad you sorted the original problem easily.
Colin McRae
