Author: Subject: Stuck steel screw in aluminium help!
AdrianH
posted on 12/8/13 at 06:15 PM Reply With Quote
This is for a cover off a Yamaha 600CC chopper style bike, model not known, but came to me with a broken screw stuck in it.
Looks as though the aluminium has oxidized and bonded very well to the screw thread. The screw could well have been stainless it was hard to tell.
I have tried my usual welding a nut to the end and failed, in the end the screw finally snapped flush.
I have also drilled down with a clearance drill but cannot remove the remaining bits in the tread.
It is only a M6 thread, the aluminium is approx 8 or 9 mm thick and I have access to both sides, but struggling to remove the steel threads.
Is there something that will dissolve the steel but leave the aluminium that I can get over the counter without raising alarm bells?
Adrian
Why do I have to make the tools to finish the job? More time then money.
posted on 12/8/13 at 06:27 PM Reply With Quote
There is a way similar to the electrolysis
I need to find the info but it will leavw al untiuched whilst dussilcing the steel
Sirr for slekkjbh usind android phibe
teegray19
posted on 12/8/13 at 06:29 PM Reply With Quote
Good quality stud extractor and a bit of heat will wip it out, I got a snapped head bolt out this way.
Or you could drill 6.8 and tap M8 if the application allows?
rodgling
posted on 12/8/13 at 06:34 PM Reply With Quote
Drill & helicoil?
madteg
posted on 12/8/13 at 06:38 PM Reply With Quote
Get some good drill bits, start with small drill say 3mm. drill up to 6mm very carefully making sure you stay central. then helicoil it
Wheels244
posted on 12/8/13 at 06:39 PM Reply With Quote
Spark erosion
I did it many moons ago when I was an apprentice to remove a snapped HSS Tap.
http://www.sparkeroding.co.uk/
big_wasa
posted on 12/8/13 at 06:48 PM Reply With Quote
Originally posted by rodgling
Drill & helicoil?
+1 if the oxidisation is that bad the thread may be no good anyway,
AdrianH
posted on 12/8/13 at 06:58 PM Reply With Quote
I will try to keep picking at it, try to get an edge and then bash-it.
All else fails then yes helicoil.
Adrian
Mr Whippy
posted on 12/8/13 at 07:02 PM Reply With Quote
Type M6 to M8 stud into google and that should give you a solution
Wheels244
posted on 12/8/13 at 07:06 PM Reply With Quote
Adrian
Agreed - maybe my solution was a bit exotic
owelly
posted on 12/8/13 at 08:10 PM Reply With Quote
Soak it in vinegar to ease the fuzzy ali.
http://www.ppcmag.co.uk
posted on 14/8/13 at 06:46 PM Reply With Quote
ALUM - Otherwise known as Potash of Alum or Potassium Ammonium Sulphate
read about it here:
http://www.tap-die.com/contents/en-uk/d296_Tip_Remove_Broken_Tap_Drill_Reamer_Tap_and_Die_Co.html
