perksy
posted on 6/9/13 at 07:33 PM |
Energy Performance Certificate (EPC)
In the process of selling Mums house privately (not using an estate agent)
Believe we now need to sort out an Energy Performance Certificate (EPC) for the buyer.
Can this be done on a DIY (locost) basis or do i have to sort out a local trained chap to come around and sort it ?
Advice welcome please and as i didn't have to do all this when we sold our last place
Smokey mow
| posted on 6/9/13 at 07:45 PM |
You'll need an accredited energy assessor to do it, we would normally charge £60 around here for one.
big_wasa
| posted on 6/9/13 at 07:51 PM |
We had ours done last week..
Its a f####ng con
£114 to be told the boiler is old and we should fit more energy saving light bulbs and an extra layer of insulation in the
loft....
[Edited on 6/9/13 by big_wasa]
fishywick
| posted on 6/9/13 at 08:20 PM |
You need a trained assessor, as the man above says, about £60.
Put your postcode in here and ring a couple...
https://www.epcregister.com/searchAssessor.html
MP3C
| posted on 6/9/13 at 08:42 PM |
We get all ours done at work and they are about £65 if I was you just replace your light bulbs with energy saving ones and it usually bumps up the
rating a bit (not much but might get you over the threshold and push it for example from a D to a C). You shouldn't have a problem with your
rating though as its a private sale, the buyers will look at it but they wont really care about it, so don't worry about putting people off with
a lower score. Also if you are worried about your score you can always ring them up and give them the charm and if you're lucky they change it
slightly and give you a better rating (only happened once to us ) worth a try though.
Matt
perksy
| posted on 7/9/13 at 07:32 AM |
Thanks for the heads up lads I'll make a couple of phonecalls.
