Author: Subject: DIY Caravan repairs
carlknight1982
posted on 11/9/13 at 04:21 PM Reply With Quote
DIY Caravan repairs
Anyone on here done DIY caravan damp repairs?
Logic will get you from a A to B
Imagination will take you everywhere.
minitici
posted on 11/9/13 at 04:53 PM Reply With Quote
Yep - turned the rotten damp caravan into a trailer!
jossey
posted on 11/9/13 at 04:57 PM Reply With Quote
Yup,
Not easy.
Dave
David Johnson
Rod Ends
posted on 11/9/13 at 06:00 PM Reply With Quote
The Caravan Show was on Quest - seem to recall one episode was about repairing a damp/rotten van.
Probably on Youtube.
owelly
posted on 11/9/13 at 06:14 PM Reply With Quote
Walls are not too bad as you cut out and replace, but delaminated floors are a pain to put right especially if its the front of the 'van and the body has lifted from the chassis.
http://www.ppcmag.co.uk
jacko
posted on 11/9/13 at 06:16 PM Reply With Quote
What make / year is your van i use to work for Swifts
carlknight1982
posted on 11/9/13 at 06:41 PM Reply With Quote
It's the wife's, late 70's monza. She won't see sense and get shot because of the sentimental
Value
jacko
posted on 11/9/13 at 06:55 PM Reply With Quote
If its that old it's time to look for a new one vans are not built to last that long believe me i use to put a van shell together one every 20 minutes
Mainly no two of us
[Edited on 11/9/13 by jacko]
carlknight1982
posted on 11/9/13 at 07:02 PM Reply With Quote
Like I said its the sentimental value for her, the damn isnt too bad ive replaced the timber in one area and am in the process of rebuilding the area.
then new electrics and gas pipes and its done well for now, i would like shot of it but she isnt having it
mookaloid
posted on 11/9/13 at 07:03 PM Reply With Quote
On your own?
Canada EH!
posted on 11/9/13 at 08:45 PM Reply With Quote
I have a 1976 Boler 13' mostly fibreglass just went 700 miles to and from Bracebridge Ontario Canada to Watkins Glen New York for a vintage race.
The only problem was the non-functioning furnace.
When I woke up Monday morning it was 6 C inside.
There is life in the old caravan yet.
coyoteboy
posted on 11/9/13 at 08:50 PM Reply With Quote
Hehe just buy a good sleeping bag, I went camping last year in the highlands of Scotland, when the snows had come properly. The down sleeping bag did a fine job of keeping me warm despite the -12C in the tent around me at 1am It's funny waking up to your breath frozen into a crisp ice layer on the flysheet while you're toasty! Getting dressed isn't much fun though.
https://www.fixmystreet.com/
Canada EH!
posted on 11/9/13 at 08:55 PM Reply With Quote
I took the 0 C sleeping bag, instead of the down one, the two burners on the propane stove soon warmed the interior up.
r1_pete
posted on 12/9/13 at 06:52 AM Reply With Quote
Top Gear have showed some hints and tips how to warm up and dry out caravans
I would think timber sandwiched between two waterproof skins would be rife with rot once the damp has took hold, as said earlier, probably best replaced and the the heartache avoided.
mcerd1
posted on 12/9/13 at 07:35 AM Reply With Quote
my parents traded in there old van with a very roten front - they took it as a project to help keep there workshop busy in the winter and sold it on at 5 times the money the next spring
it can be done, just depends how much you want to do it.....
+1 a proper sleeping bag makes all the difference - and its better than gassing your self with some doggy old heater
Originally posted by coyoteboyGetting dressed isn't much fun though.
that depend what you did with your clothes....
if you put them in a bag and use that as a pillow then they are nice and warm in the morning
[Edited on 12/9/2013 by mcerd1]
posted on 12/9/13 at 09:02 AM Reply With Quote
I repaired the roof round the vent in our old caravan to keep it going for a couple of years but when the front started to rot it was beyond economic sense so it went to the local allotments as a shed. When they get so bad they are not safe to tow and it would have been a ground up job. The original wood was about 30mm square and only treated where it met the floor up to about 250mm up the inside. It was only hardboard/ fibreboard inside so it was easy to cut with a Stanley knife to expose the rot.
[Edited on 12/9/13 by Peteff]
Bluemoon
posted on 12/9/13 at 09:27 AM Reply With Quote
Boler/eriba/airstream caravans have a different construction than the" normal" white box uk caravans.. They are worth keeping.
The "normal" uk construction is from laminated aluminium-expanedplystyene-fiber board sandwich with a soft wood wooden frame inside, no real structural integrity after a while (and sometimes from new) they leak where the each panel meets, trip strip is fitted, window cut-outs etc. etc. and after a while the frame rots. The sealent used on the seams is only good for 3 to 10years or so then it starts to loose it's elasticity and leaks.... It is possible to keep them in good condition but requires good maintenance (replacing old sealant for example under the trim strips) and damp checking.
The floors are a simlar storey and as there is no metal frame there on most (the A frame chassis provides only minimal stiffness/support) so the floor will flex under way. It's a ply -insulation -ply construction.
The composite construction can also de-laminate and that can be a major pain..
The bottom line is 10 years is a good run for one hence the low resale value at that point..
Dan
[Edited on 12/9/13 by Bluemoon]
