Author: Subject: indespension trailer suspension
austin man
posted on 15/9/13 at 06:46 PM Reply With Quote
has any one refurbished these units, Just bought a trailer to find that the units have had spacers to get rid of camber issues I can only asume this id down to worn rubbers in the suspension so I am looking to refurb them
owelly
posted on 15/9/13 at 08:17 PM Reply With Quote
The box section trailing arms usually twist due to overloading or corrosion. If so, the units are scrap. Likewise, if the rubbers are perished, scrap. Are you sure the bearings are ok? Folks often hide knackered bearings with spacers!!
http://www.ppcmag.co.uk
austin man
posted on 15/9/13 at 08:34 PM Reply With Quote
the cent of the shaft doesnt appear to sit central in the box section, I think that the unit may have been carrying too much weight for the units
ste
posted on 15/9/13 at 10:22 PM Reply With Quote
Are they individual units or axle units?
Individual ones are usually 8 hole mounts and easy to swap over.
For 2 ton, budget around £350
Mr Whippy
posted on 15/9/13 at 11:07 PM Reply With Quote
I don't think they are designed to be rebuilt I suspect there are assembled using an almighty press
[Edited on 15/9/13 by Mr Whippy]
dhutch
posted on 16/9/13 at 03:51 AM Reply With Quote
Originally posted by Mr Whippy...there are assembled using an almighty press.
The press is actually not a large as you might think, but I also agree that ive not heard of anyone refurbishing a unit, given it appears to be fairly random which bit fails first its probably false economy to try.
Daniel
