PioneerX
| posted on 25/10/04 at 03:42 PM |
A game to waste some time
As title really, I got stuck on level 16 for ages but just found the solution.
http://storm.isw.student.khleuven.be/~tom/stuff/funstuff/shock
wave/laser/laser.swf
Good luck
heinlein
| posted on 25/10/04 at 06:49 PM |
I took a quick look, but I don't know how to play. I dragged the mirror where I wanted it and turned it the way I wanted it, but the beam
didn't bounce, it just stopped dead at the mirror and nothing else appeared to work after that.
When you're lying in the midst of the Afghan plains and the women come out to cut up the remains; just roll to your rifle and blow out your
brains and go to your god like a soldier.
scoobyis2cool
| posted on 25/10/04 at 07:52 PM |
u have to use the arrow buttons at the bottom to rotate the mirror...
Pete
Ben_Copeland
| posted on 25/10/04 at 08:38 PM |
OMG level 11 is annoying
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
scoobyis2cool
| posted on 25/10/04 at 11:53 PM |
I'm stuck on level 18 and it's getting late, I'll try again in the morning...
Pete
PioneerX
| posted on 26/10/04 at 10:06 AM |
took me ages to get level 11 too. It so annoying when you finally realise the answer is so simple you missed it everytime.
andylancaster3000
| posted on 26/10/04 at 10:50 AM |
I can't even do level 4 with the three 'splitters'... help!
| posted on 26/10/04 at 11:43 AM |
Give up now
It just gets harder.
ned
| posted on 26/10/04 at 12:23 PM |
13 is proving troublesome, got 11 in the end...
beware, I've got yellow skin
andylancaster3000
| posted on 26/10/04 at 12:30 PM |
Cheers!!!
Ben_Copeland
| posted on 26/10/04 at 01:24 PM |
I can get all but one light on level 11
EDIT: HAHAHA did it
[Edited on 26/10/04 by Ben_Copeland]
Ben
Roadster
ned
| posted on 26/10/04 at 01:37 PM |
i had all but one, then the solution just clicked into place. easy when you now how isn't it ben
derf
| posted on 26/10/04 at 02:46 PM |
Level 1: This one is easy, one mirror, one bulb.
Level 2: Place the interior mirrors before the outside one to avoid triggering the bombs.
Level 3: Laser beams travel through bulbs and don’t stop.
Level 4: Look for the diagonals.
Level 5: The first tricky one. The key: Refractors can be used more than once.
Level 6: All the splitters should be close to the central block.
Level 7: The double mirror goes just inside the door.
Level 8: The refractor points down, and goes to the left of the two bulbs in the center that the laser hits.
Level 9: The refractor goes at the very top, and the double sided mirror is the third thing the beam hits.
Level 10: The top clear part of the board is very very important. That is your shortcut.
Level 11: A tough one. The gap on the leftmost wall should have an ‘X’ of laser beams in it. The refractor and one mirror stay on the emitter’s side
of that wall.
Level 12: All of the splitters except 1 are within 1 square of at least 2 bulbs. That splitter is 4 squares up and left from the laser.
Level 13: This should be as symmetrical as possible. There’s just a little jog with the refractors in the lower left.
Level 14: While 2 beams at once will turn a bulb off, 3 beams at once will turn it back on. This is key to this level.
Level 15: You do not need the double sided mirror. Just place all the mirrors and refractors carefully before you slide the mirror in that will
activate the laser (just like level 2, trace the path out beforehand so ou don’t hit any bombs)
PioneerX
| posted on 26/10/04 at 03:05 PM |
yes, I found the hints site too, but only goes as far as level 15. I'm stuck on 18, HELLLLLP.
scoobyis2cool
| posted on 26/10/04 at 03:10 PM |
I've got all but 1 bulb on level 18 with 3 mirrors left but just can't see how to get that last one!!
Pete
PioneerX
| posted on 26/10/04 at 03:14 PM |
Always two bulbs left and one mirror. Does not seem to mater which way I do it, I still get two unlit bulbs
Chris Green
| posted on 26/10/04 at 03:16 PM |
an excellent game! cheers.
This one requires a similar way of thinking....
Dyson Game
Chris Green
| posted on 26/10/04 at 03:28 PM |
The tip for number 9 doesn't make sense to me? I can't see how the double sided reflector can be the third thing the beam hits?
I've managed to get the bulb in the middle, but not the one at the top.
Has anyone got any other suggestions?
Cheers!
EDIT: Got it now, the double sided mirror is actually the 4th thing the beam hits.
[Edited on 26-10-04 by Chris Green]
PioneerX
| posted on 26/10/04 at 03:55 PM |
best I can manage on level 18.
Chris Green
| posted on 26/10/04 at 03:57 PM |
I'm stuck on level 10
Ben_Copeland
| posted on 26/10/04 at 04:26 PM |
Ok, the hint for 13 really really doesn't help
EDIT : Got it Now, it does help a little but it's still not easy !
Ben
Roadster
heinlein
| posted on 27/10/04 at 01:43 AM |
Once I figured out which side of the mirror was reflective in level 1; I progressed fairly quickly to level 11. Still working on that one, but not
using any hints.
[Edited on 27/10/04 by heinlein]
heinlein
| posted on 27/10/04 at 06:25 AM |
12-15 are easy in comparison to 11.
jollygreengiant
| posted on 27/10/04 at 10:38 AM |
Ok folks thats level 18 completed on to 19!
Can post answer if requested but you will kick yourselves!
Enjoy
ned
| posted on 27/10/04 at 11:54 AM |
level 18 done
my tip is the top two bulbs are lit by a single horizontal laser, work backwards from there
pioneerx, you're along the right sort of lines..
[Edited on 27/10/04 by ned]
