smart51
| posted on 4/1/14 at 08:16 PM |
coating for sliding steel parts
I'm making a recumbent trike and part of the folding mechanism is a steel tube that slides inside a slightly larger steel tube. Both are made
from CroMo bicycle tubing. If they're painted I suspect it will all be scratched off very quickly. What's the best stuff to coat / plate
the tubes with to stop corrosion but allow them to slide without ripping it all off?
mookaloid
| posted on 4/1/14 at 08:35 PM |
Chrome?
big_wasa
| posted on 4/1/14 at 08:37 PM |
What about Teflon coating ?
http://www.plasticcoatings.co.uk/ptfe-coating.html
smart51
| posted on 4/1/14 at 09:56 PM |
both good ideas. What about something you can do yourself?
SPYDER
| posted on 4/1/14 at 11:24 PM |
What about regular use of Muc off Dry lube spray or a similar PTFE type spray?
| posted on 5/1/14 at 02:15 AM |
Could you bush them with nylon or maybe brass?
