Author: Subject: Duratec bellhousing / flywheel setup?
TrophyJem
posted on 6/2/14 at 10:29 AM Reply With Quote
I'm just about to press the go button on ordering the bellhousing and flywheel for my Duratec install, but I'm slightly worried about what will and won't work together.
I was thinking of the RWD bellhousing
http://www.rwdmotorsport.com/duratec-engine-to-ford-gearbox-cable-clutch-bellhousing.html
With a Turbosport 3.1KG flywheel from this page (Its cheaper than the RWD one)
http://turbosport.net/acatalog/Flywheels.html
And I'll use this spigot bearing
http://www.rwdmotorsport.com/spigot-bearing.html
I currently have a good Pinto clutch so I'm planning on using that.
My fork and bearing are from a Sierra, so I think I need the RS2000 version of both.
Has anybody else gone with this setup?
Any problems?
[Edited on 6/2/14 by TrophyJem]
tims31
posted on 6/2/14 at 11:49 AM Reply With Quote
Not too sure about the rest of it but the Spigot bearing you could certainly get cheaper from Burton Power, about £10 less
http://www.burtonpower.com/crank-spigot-bearing-21x15mm-fp347.html
Build: http://www.martinsfurybuild.co.uk/
big-vee-twin
posted on 6/2/14 at 06:40 PM Reply With Quote
There are ST150 flywheels on eBay much cheaper.
http://www.triangleltd.com
