Author: Subject: Pinto into Locost
Monty2556
posted on 2/3/14 at 06:55 PM Reply With Quote
Pinto into Locost
Just had many replies on a topic I posted -x flow heads. Really good feedback but clearly putting me off tuning a 1300 x flow. No problem with that. Just so happens I've got a rebuilt 2.0 Pinto engine in the garage. So -
Is it the done thing to put a Pinto into a Locost? Is is possible/wise? And
Will it bolt onto a 1300 gearbox (with or without a modified bell housing). If not, does a type 9 fit a Locost?
wylliezx9r
posted on 2/3/14 at 07:37 PM Reply With Quote
Pinto into a locost.......do bears sh1t in the woods ?
George Best
ali f27
posted on 2/3/14 at 07:39 PM Reply With Quote
Everybody is going to tell you its a crap engine too heavy got to put a zetec in dont listen use it bolt it straight in no fuss and you will love it
snapper
posted on 2/3/14 at 07:43 PM Reply With Quote
All ford gearboxes fit all ford engines upto and including Zetec
The Pinto was mated to the 4 and 5 speed type 9 so easiest to fit
Yes a pinto will fit a Locost but depending on what model you may find little niggles such as Pinto engine is taller and a bit longer
I eat to survive
I drink to forget
maximus1
posted on 2/3/14 at 07:50 PM Reply With Quote
Pinto on 40s
If you have a pinto put it in you will love it, where are you based
I'm in yorkshire if you would like to look at mine I will take you for a spin ?
Monty2556
posted on 2/3/14 at 10:04 PM Reply With Quote
Thanks for the advice. Don't know why I put this topic on "wanted" so I'm going to transfer it to "engines" . Once again, thanks.
