Author: Subject: Laser cutting
Benzine
posted on 12/3/14 at 04:19 PM Reply With Quote
Laser cutting
Does anyone on LCB do laser cutting? The person I used before hasn't been active on the forum for years. I have a .dxf file and I'm after getting an exhaust flange cut in stainless steel (10mm-12mm)
cheers
iank
posted on 12/3/14 at 05:10 PM Reply With Quote
Some leads in this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=186146
Anonymous
snakebelly
posted on 12/3/14 at 10:08 PM Reply With Quote
Thom at h2oprofiling just did me a custom trigger wheel at an ok price with a good lead time. Does it. Have to be laser cut? Surely water cut should be plenty good enough?
Benzine
posted on 12/3/14 at 10:26 PM Reply With Quote
Thanks for the replies, I've fired off a few emails. Doesn't have to be laser, but from what I've read water cutting is more expensive so I was just going for the low cost option
[Edited on 12-3-2014 by Benzine]
tims31
posted on 13/3/14 at 08:00 AM Reply With Quote
Not on LCB but have heard good reports about this company near me. NTDWM
http://www.laserfab.co.uk/
They do laser and water cutting
Just had a look at the links above and the one that says Gutridge is the same as laserfab
[Edited on 13/3/14 by tims31]
Build: http://www.martinsfurybuild.co.uk/
scutter
posted on 13/3/14 at 09:27 AM Reply With Quote
I can recommend FastDan on this site, great communications and double checking for a set of Alfa exhaust flanges.
Regards Dan.
