Author: Subject: Bolt in back of duratec bellhousing
TrophyJem
posted on 14/3/14 at 12:26 PM Reply With Quote
I understand that I need to put a bolt in the back of the duratec bellhousing to stop a bit falling out of the gearbox.
Question is, do I put the top of the bolt flush with the back of the bellhousing or should there be a gap?
Paul Turner
posted on 14/3/14 at 01:48 PM Reply With Quote
Near flush as you can get it, certainly not proud. Just to confirm, its only needed with a standard box, the HD box as fitted to some V6 models (has the external layshaft spiggot support) do not need it.
TrophyJem
posted on 14/3/14 at 01:51 PM Reply With Quote
Mines the standard box.
Cheers for your help
