| posted on 5/4/14 at 03:19 PM |
And today's rant is - short cables on electric drills!
Why oh why do they insist on putting short cables on mains-powered electric drills?
I seem to recall that there was some regulation/recommendation to limit lead length to 2m (maybe 6ft) but at that length you can't even drill a
hole over a door (I've spent the last 3 days running cables around the house). The only alternative is to extend the cable using some sort of
connector, as even with an extension lead at your feet you can't get anywhere near the ceiling - and using a connector negates any dubious
safety benefit of keeping the lead short.
I could replace the lead entirely, but that could turn out to be a bit of a faff on a cheapo Chinese SDS drill! I think that is the way I'll
have to go though...
</end rant>
| posted on 5/4/14 at 03:43 PM |
</end rant>
tegwin
| posted on 5/4/14 at 03:44 PM |
As rants go thats a pretty wee poor attempt.... I mean..where is the swearing...comparing the lack of length to other things in life that are never
long enough etc.... 2/10!
www.verticalhorizonsmedia.tv
| posted on 5/4/14 at 03:45 PM |
Could be why most tradesmen seem to use cordless tools these days
blakep82
| posted on 5/4/14 at 04:01 PM |
After reading that, I don't agree, I just feel embarrassed for you
Get a decent extension cable. I've got one about 10m long, never struggled to reach a ceiling using it. Not sure why you cant reach the ceiling
with an extension tbh
As for rants, try harder next time
[Edited on 5/4/14 by blakep82]
________________________
owelly
| posted on 5/4/14 at 04:23 PM |
I have a really short one. I never quite reaches where I want it to. Even swmbo says it's not long enough to be of any use to her. I think
that's why she borrows my mates because his is longer. She's even mentioned a battery powered one so I guess that's what I need.
http://www.ppcmag.co.uk
James
| posted on 5/4/14 at 04:29 PM |
I agree- too short is bloody annoying! I guess it saves money on flex!
A single gang extension lead would be the quick and dirty option instead of cracking the casing open and replacing the flex!
James
[Edited on 5/4/14 by James]
- Muhammad Ali
Irony
| posted on 5/4/14 at 05:07 PM |
I have two corded drills. One with a 3m cord and one with a 10m. The 10m is bloody annoying to store and get out. Constantly kinks. Nah
don't agree.
I wouldn't put them in room 101.
jacko
| posted on 5/4/14 at 05:49 PM |
 poor you Owelly
Macbeast
| posted on 5/4/14 at 06:07 PM |
However long it is, there are going to be times when it's not long enough.
| posted on 5/4/14 at 07:54 PM |
Story of my life!
| posted on 5/4/14 at 07:59 PM |
I don't care if you lot think my rant is second-rate - the short lead has been annoying me for the past 3 days! All the holes I had to drill
were over the door frames, and every time I had to put my extension reel on the top rung of my steps so I could get unrestricted access.
Anyway - the job's done now, so I'll probably forget about it until I need to do something else in 6 months' time and get all cross
again!
| posted on 5/4/14 at 09:28 PM |
Carrying the weight of an extension lead very the flex makes the drill cumbersome and isn't great for the flex and connections anyway.
blakep82
| posted on 5/4/14 at 09:41 PM |
if the weight of a bit of cable is a problem, a longer cable won't fix that
and i can't see how one of these will weigh much more than a longer cable?
http://cdn.toolstation.com/images/130125-UK/images/library/stock/webbig/85415.jpg
| posted on 10/4/14 at 08:15 AM |
It's not the weight of the cable, it's the fact that if you are up a ladder or standing on a chair etc. with a short flex and an extension
lead, the extension lead socket assembly will be dangling in the air unless you can find somewhere convenient to rest it on. A longer flex on the
drill avoids this.
| posted on 10/4/14 at 09:36 AM |
The plug/socket is also vulnerable and can easily be hit, or pulled too much.
As it happens, I think I've found a solution - I might get one of these Duraplug connectors:
They're made for lawnmowers and the like, but its current-carrying capacity is well above the requirements of my SDS drill, and it's not
too big to hang from the drill lead while I'm up on a ladder.
DW100
| posted on 10/4/14 at 11:59 AM |
It seems to be an issue with power tools designed for DIY use. I have plenty of Trade Bosch blue, Makita and ELU stuff that have leads around 3-4
meters and are fine. I also have a Black and Decker jigsaw that the lead isn't even long enough to run across a 4 foot sheet without an
extension.
Guess they are just cutting back on the cost, but it does make the job more difficult and dangerous having extension leads balanced on things.
| posted on 10/4/14 at 01:44 PM |
Yes - just about every other power tool that I own has a respectable lead length - circular saw, jigsaw, angle grinder, etc - but electric drills seem
to get lumbered with the short leads.
