cb500t
| posted on 11/4/14 at 04:13 PM |
Plumbing in a radiator
Why can you not use stainless braided hoses to plumb in a radiator to a central heating system?
Ben_Copeland
| posted on 11/4/14 at 04:32 PM |
They aren't designed for central heating. Constant heat, pressure and they look like a bodge. Could be restrictive on the system too
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
cb500t
| posted on 11/4/14 at 04:42 PM |
Cheers....
tegwin
| posted on 11/4/14 at 05:43 PM |
Why would you want to?
I fitted a couple of enormous industrial flexies between a heatpump unit and building to reduce vibrations but they were damn expensive and designed
for the job!
Look a lot nicer to use some shiny copper pipe for internal rads
www.verticalhorizonsmedia.tv
| posted on 11/4/14 at 06:03 PM |
Spit flex conduit put over the pipes improves the appearance of the pipes these days you can get all sorts of colours.
SteveWalker
| posted on 11/4/14 at 06:51 PM |
I can see why flexi would be useful, as you could lie the radiator down for decorating or even cleaning behind it, but having a lockshield with a
built in drain is almost as good.
You actually can use flexis on radiators. I don't know if they are any different from normal flexis, but they are supplied with kickspace
radiators, so that you can install and remove them without disassembling the cupboard above.
