Author: Subject: Inner tie rod removal and fitting tool needed
posted on 11/4/14 at 08:04 PM Reply With Quote
Hi all,
Working on refurb in the steering rack and I need to fit new tie rods.
Never having done this before and baffled by the lack of flats on the joint to get a spanner on I googled and realised there is a special tool for the job.
Q1. Has anyone around Winchester or Basingstoke got one they would be willing to lend for a day or two?
Q2. Failing that, has anyone got a tip or technique using ordinary tools?
Nick
mark chandler
posted on 11/4/14 at 08:19 PM Reply With Quote
I attacked mine with some stilsons, then filed the burrs down when done.
As they are staked it takes a lot of force to get things moving.
posted on 11/4/14 at 08:26 PM Reply With Quote
OK, have a set of those.
How did you hold the rack stationary, just clamp the case in a vice or clamp the actual rack itself?
Don't want to damage the rack or casing!
Nick
rodgling
posted on 11/4/14 at 08:29 PM Reply With Quote
I ground flats on mine - I only needed to take ~0.5mm off each side to create a flat that a 32mm spanner would go on, so I'm sure it won't have compromised the strength.
renetom
posted on 12/4/14 at 07:00 AM Reply With Quote
Hi
Vice & stilsons to remove & put back.
Before re-assembly make sure parts are thoroughly degreased
Use threadlock + nice & tight.
File off any nibs as ness.
Good luck.
posted on 12/4/14 at 07:02 AM Reply With Quote
Clamp the rack itself not the outer casing and use soft jaws for the vice although the tool your asking for does the job on the car it's best not to take any chances
posted on 6/5/14 at 01:11 PM Reply With Quote
Managed to complete the rack rebuild on my 205 project. The above tip on Stillsons worked perfectly
Little Photobucket story here showing the strip down and rebuild, might be useful for others doing the same job....
http://s736.photobucket.com/user/nick-205/story/33079
After stripping it down and some advise on the 205 GTI Drivers forum, I replaced the £3 plastic bush in the rack housing itself before fitting the new track rods. Problem solved and all play removed from the steering . That's the complete front suspension and steering renewed/overhauled now. Car feels sooo much better although it now needs to loosen up a bit
Took it to get the tracking checked at lunchtime and it was 0.25 degrees out, having reassembled everything by eye I was quite pleased with that.
