teegray19
| posted on 30/4/14 at 06:23 AM |
Go pro black help!!?
Bought a go pro off groupons from that company with the worst reviews in the world.. (Only found this out after)
Anyways... I can't get the go pro to actually record a video, every video is corrupt! I've tried 2 different SD cards and it will not
work! So frustrated now, does anyone have pointers or had similar problems?
Built Formular 27 with 1600cc crossflow, 1700cc 0 miles crossflow, Kawasaki ZZR1100
Agriv8
| posted on 30/4/14 at 06:40 AM |
sounds to me the the the play back device / programe may not be compatible with the format that the vidio has been recordeded in. there are lots of
different compresion for even the same file type ( EG .MP4 ) you need to have somthing that will uncompress and open the File.
I have founf VLC ? player good at this.
but dont have a go pro so only a guess
ATB agriv8
rgrs
| posted on 30/4/14 at 06:47 AM |
What speed are your sd cards ?
Go pro needs class 10 cards otherwise this will lead to corruption.
Roger
Ben_Copeland
| posted on 30/4/14 at 07:34 AM |
As said, Use the go pro software and class 10 high speed card, around 80mb/s
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
HowardB
| posted on 30/4/14 at 07:50 AM |
for playback and device control download the free app, and the free editing suite. The app will let you make sure that your device is working, as it
shows a live screen feed.
The editing suite does just that,. and includes playback, title editing etc.
as above though, check the speed of your cards, or try recording at the lowest resolution and frame rate, or just take some still shots,. see if they
work.
hth
Howard
jeffw
| posted on 30/4/14 at 09:09 AM |
quote: Originally posted by teegray19
Bought a go pro ...... worst reviews in the world..Anyways... every video is corrupt!
Ummmm.....
Ben_Copeland
| posted on 30/4/14 at 09:12 AM |
Ummmm.....
Not the camera, the website!
Ben
Roadster
jeffw
| posted on 30/4/14 at 09:15 AM |
OK....just checking that it is a working version of a genuine GoPro...
theduck
| posted on 30/4/14 at 11:05 AM |
Iirc these cameras had no serial numbers? If so no chance with warranty support. If it does have a serial number you should be able to get support
from Gopro
Ben_Copeland
| posted on 30/4/14 at 11:25 AM |
from Gopro
If they don't have serial numbers, then they are probably fake!
Ben
Roadster
Nick DV
| posted on 30/4/14 at 01:07 PM |
I've never heard of a fake GoPro, but if you go here you'll find as much help as you're likely to get.
http://goprouser.freeforums.org/index.php Chances are it'll be something simple
"The force will be with you, always!"
Davey D
| posted on 30/4/14 at 02:12 PM |
As above.. for HD recording you need a class 10 card. Note that not even all class 10 cards are equal. i bought one of the Samsung cards recommended
by GoPro just to make sure there would be no issues.
if you dont have a class 10 card try settings the resolution, and fps to as low as it will go on the camera, as you dont need as fast a card at lower
quality. If it all works fine then you know the camera records ok, and that it will be the speed of the card that is the issue
teegray19
| posted on 30/4/14 at 04:50 PM |
Thanks for the replys guys!
kenton
| posted on 30/4/14 at 05:08 PM |
I bought 2 from that Groupon deal. Both work well and have serial numbers.
The only annoying thing is the leads are very short and trying to find a 10 pin mini usb lead is nigh on impossible.
Kenton
HowardB
| posted on 30/4/14 at 08:05 PM |
any news?
Howard
ashg
| posted on 30/4/14 at 10:17 PM |
i got one from the group on deal too. it has a serial and works fine. did you install the phone app and watch the vids back on your phone direct
from the camera. also make sure you have the latest firmware loaded onto the camera. you can either do it with the phone app or download the
firmware onto the computer and do it with the usb cable.
as for the company being crap well they sold 1000 go pros in a morning everyone i know that ordered them got them in a couple of days and to be honest
i have only seen about 2-3 complaints that i found on-line. its not perfect but its not a bad percentage for how many they sold.
if i recall correctly i think the newest firmware has improvements to support even more memory cards, although as others have said it must be class
10.
i have 32gb sandisk ultras and extreems they both work fine also have a cheap lexar 32gb class 10 card and that works ok too. even a crap 2gb card i
found from an old phone seemed to work and that was a class 6. what brand/class are the cards you currently have?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
