leon51274
posted on 1/5/14 at 09:44 AM |
Fuel tank earth
Morning,
It's been brought to my attention of the requirement of earthing the fuel tank for IVA, something I must confess had completely been forgotten
about!
There is currently an earth for the sender but I'm under the impression that this isn't good enough. My initial thought was to put an
earth via one of the aluminium brackets that holds the tank in place, however these have rubber strips between the brackets and the tank which makes
it no good what so ever!
How have you guys gone about earthing your fuel tanks?
This is something I need to sort PDQ as IVA has now been paid for!
All comments and suggestions appreciated.
Leon
loggyboy
posted on 1/5/14 at 10:01 AM |
Is the metal mount/bracket of the tank connected directly to the chassis? If so its automatically earthed.
Mistral Motorsport
leon51274
posted on 1/5/14 at 10:07 AM |
Yes it is, but would the rubber in between them not cancel out the fact that the bracket is earthed? Or am I missing something!
Slimy38
posted on 1/5/14 at 10:19 AM |
Yep, the rubber straps effectively insulate the tank from electricity as well as vibration. If I remember correctly the sender that I'm going to
use on mine is also insulated with a gasket, so while the sender will be grounded the tank won't be.
I would just go for a hole drilled in the tank, then either a rivnut or rivet to secure a tag for an earth wire. Just need to ensure the swarf from
the hole is removed.
[Edited on 1/5/14 by Slimy38]
leon51274
posted on 1/5/14 at 10:24 AM |
use on mine is also insulates with a gasket, so while the sender will be grounded the tank won't be.
Umm, this was what I didn't want to do but at the moment I can't see any other way around it. My sender also sits on a plastic gasket type
thing so that's also a no go.
adithorp
posted on 1/5/14 at 10:30 AM |
The sender and it's earth are grounded to the tank via the securing bolts. The IV earth requirement is to prevent static build up so a large
earth isn't required and I thought the sender earth was sufficient. If not you could trap a wire between the straps rubber and tank (on the tank
side).
http://jpsc.org.uk/forum/
theduck
posted on 1/5/14 at 10:31 AM |
I have earthed my tank and using the captive bolt that the sender fastens to. Could you not do similar?
leon51274
posted on 1/5/14 at 10:48 AM |
I've just checked for continuity between one of the bolts on the sender too the fuel tank and all is ok, another job off the list!
Cheers for the help chaps.
serieslandy
posted on 1/5/14 at 02:48 PM |
I was going to surgest using a jubille clip around one the the outlets with a ring crimp.
Like an earth clamp for copper pipe.
leon51274
posted on 1/5/14 at 02:56 PM |
Rather than risking anything I've fitted a separate earth from a sender bolt to chassis and checked the tank with a multimeter and all is nicely
earthed.
Cheers for the advice.
The Black Flash
posted on 1/5/14 at 03:14 PM |
Get a photo of it if it's somewhere hard to see, as he might want to look at it. Mine was happy with a photo.
leon51274
posted on 1/5/14 at 03:38 PM |
Its all nicely in view.
renetom
posted on 1/5/14 at 04:11 PM |
Hi
The senders earth tag to the chassis is fine
Our examiner actually checked ours & was happy
with that.
