Author: Subject: How to make a hole in a silicon hose
johnH20
posted on 10/5/14 at 08:47 PM Reply With Quote
I need to make a 10 mm hole in a silicon air inlet hose to take a breather pipe via T piece. I am thinking that maybe a wood drill on slow speed backing up the tube from within might be the way to do it. Don't want to ruin the hose of course so would
appreciate advice on this one. TIA.
r1_pete
posted on 10/5/14 at 08:54 PM Reply With Quote
Punching it with a piece of 10mm dia tube sharpened on the end would be my preferred method, you would end up with slightly less than 10mm which would help sealing.
HowardB
posted on 11/5/14 at 05:08 AM Reply With Quote
+1
Howard
renetom
posted on 11/5/14 at 08:12 AM Reply With Quote
Plastic unequal T piece ?
craig
posted on 11/5/14 at 08:44 AM Reply With Quote
Try a 10mm wad punch if you cant find the correct size pipe as suggested, they are not expensive. Drill bits usually dont make a neat enough hole.
adam1985
posted on 11/5/14 at 10:51 AM Reply With Quote
10mm copper tube heat up with blow lamp till red hot and push it through or try 8 mm tube if you want a tight fit.
Plumbers trick to melt through plastic tanks to fit connections never done it on rubber tube though.
posted on 11/5/14 at 11:53 AM Reply With Quote
Silicone hose doesn't melt so this is unlikely to work. A punch is the only way you are going to get a really neat hole, a drill bit will chew the edges up.
daniel mason
posted on 11/5/14 at 03:51 PM Reply With Quote
unless you cut the hose and fit a T piece!
johnH20
posted on 11/5/14 at 04:37 PM Reply With Quote
Well the DIY punch worked a treat - quick and easy. Thanks for the idea.
