Author: Subject: Indicator stalk
Sierra
posted on 9/7/14 at 01:06 PM Reply With Quote
Indicator stalk
Afternoon all, just after some advice and ideas. My avon currently has buttons as indicators on the dash but it can be very awkward using them, I did have the buttons on the steering wheel which is fine but I've now got a quick release.
How easy is it to fit an indicator stalk and which ones are people using that aren't too large and ugly.
jossey
posted on 9/7/14 at 04:42 PM Reply With Quote
Get a 3 way switch turned on its side.
Easier to fit n less ugly
I used a sierra stalk n then saw the 3 way switch idea.
David Johnson
renetom
posted on 9/7/14 at 04:59 PM Reply With Quote
stalk
Hi
We used a land rover stalk
which gave us indicators, main beam & dip
headlamp flash & horn.
it clamps around the steering column but you have to make a box or hood to hide it.
the indicators dont return but thats no great shakes with a stalk.
good luck
Rene
pekwah1
posted on 9/7/14 at 05:05 PM Reply With Quote
What steering column have you got on the car?
Would probably make a difference to what can just bolt on.
Sierra
posted on 9/7/14 at 05:59 PM Reply With Quote
I'm not sure what steering column it is but the boss when bolted to it is about 2mm from the dashboard.
19sac65
posted on 10/7/14 at 03:21 AM Reply With Quote
Try SVC
They do the old mini style stalk with or without light on the end
Universal clamp to your outer column and 3 wires
Just the right length too
About £15
daveb666
posted on 10/7/14 at 07:31 AM Reply With Quote
Laguna stalk has indicators, horn, side lights, headlights, main beam, fog AND horn.
