sdh2903
| posted on 28/7/14 at 03:37 PM |
Timber garage on side of house?
I'm moving to a new house this Friday. The integral garage is to be converted into a bedroom straight away. My plan was to build a garage joined
to the other side of the house.
Now funds will be tight due to moving and the fact that SWMBO has decided we need new Everything so my initial plan was to buy/build a shed for the
time being for tools bikes storage etc. but as I hate doing things twice my mind has started to wander and think about building a timber garage. This
would save money on footings over a block structure as I could get away with a floating slab maybe 5 in thick with rebar. Plus I could do all the
work myself. Quick sums suggest around 1500 quid as I can get all the timber at trade cost.
The only sticking point is possibly the roof. I couldn't really use tiles as It would be a bit heavy I suspect for a floating slab? I
wouldn't want a felt roof so would prob have to be coroline corrugated or something similar?
So any thoughts? Should I just wait until I have the pennies to do a proper block and tile job??
whitestu
| posted on 28/7/14 at 03:56 PM |
I built a timber garage on a slab base at my old house using Coraline for the roof. It was great and served the purpose I needed it for and was really
cheap to build.
It didn't really have any foundations and just had damp proof membrane, sand and slabs as a base.
Obviously not as secure as a brick garage but you can't have everything.
If properly installed Coraline lasts for ever! It's worth putting on top of OSB board to stop condensation though.
I'm going to build a car port at my current house, using twin wall polycarbonate panels for the roof, which may eventually become a garage as it
already has two sides [house and neighbours garage] and a garage door going into the drive.
Stu
[Edited on 28/7/14 by whitestu]
| posted on 28/7/14 at 04:22 PM |
Neighbour of mine built a timber extension on the back and clad the roof with wooden shingles. No idea what how the cost compares, but it looks good
and has weathered in nicely over the last couple of years.
fireybiscuit
| posted on 28/7/14 at 05:29 PM |
I built a timber extension on the top of my existing brick and block garage. The single pitch roof is recycled mild steel cladding from the side of an
industrial unit - very light and cheap! I also thought about EPDM membrane fixed to OSB boards. The rubber membrane is very easy to fix using PVA and
should last for ages.
I laid a cover of roofing membrane down first to prevent condensation. Condensation shouldn't be an issue with the EPDM/OSB combo
Thinking of a second storey next year.
talkingcars
| posted on 28/7/14 at 06:05 PM |
When I built my workshop last year I spent a lot of time looking at roof prices, by far the cheapest durable solution was coroline sheeting, I did the
whole 4.4m by 2m structure for £75 (the most expensive part of the whole build/rest was mostly scrap salvage), it stood happily through last winters
rains.
My neighbour erected a similar size workshop/shed at least 15 years ago using the same, I guess it has no real support underneath as it has sunk a bit
but it is still weather proof.
The garage loft conversion looks neat.
| posted on 28/7/14 at 06:14 PM |
I reckon (might be wrong tho) you can get a concrete sectional garage now and use blocks inside it later?
Smoking Frog
| posted on 28/7/14 at 08:56 PM |
I don't know if it's needed, but you may have problems with planning permission for a wooden structure connected to the house. I'd
say wait until you have more funds available or if you have rear access build it on the back.
sdh2903
| posted on 28/7/14 at 09:08 PM |
This was the issue I was presuming I might encounter. I'm gonna give the planning office a call tomorrow. It's the only location on the
property where the garage can go and it needs to be attached to the house to maximise width.
Out of interest how much £££ for an attached garage so only 3 walls approx 4m x 6m in size?? Also I already have a new garage door so wouldn't
need one.
tegwin
| posted on 28/7/14 at 09:33 PM |
Its going to depend what you want to do with the garage...
I have a single skin block built garage, rendered on the outside with a new OSB and EPDM roof. Its great but in the winter the condensation inside is
a little annoying.
If you are going to the effort I would do it properly. Either a timber or brick/block thing with the correct insulation etc so its warm and dry all
year.
www.verticalhorizonsmedia.tv
sdh2903
| posted on 29/7/14 at 08:40 AM |
The garage will be used for general storage and eventually another car build. It will be fully insulated as I've battled with a cold damp
workshop for the past few years and I want something better. The more and more I think about it the more I think waiting to do a proper double skinned
block build and tile roof would be the best option
mark chandler
| posted on 29/7/14 at 09:09 AM |
Build it with insulated celcon blocks if you want a rendered outside. They are lovely and light to lift precisely cut so you use their glue, if you
use sand and cement as adhesive then weak mix, 7:1.
Much easier than double skinned and capable of bearing load.
For myself I am just starting on an oak framed barn type building, will clad with wood and use insulated boards on the inside.
Regards Mark
DIY Si
| posted on 29/7/14 at 12:12 PM |
If it's just a single storey, then there's no need to double skin it. You'll just use more materials and space up. My garage, whilst
detached and massively overbuilt, uses 140mm wide blocks with 100mm of rockwool RWA45 insulation on the inside. It's lovely all year round in
there.
Sun Tzu, The Art of War
