smart51
| posted on 8/8/14 at 11:37 AM |
Rough cost of laser cutting
I'm planning a project that would need some 1mm stainless steel plates laser cut. 180 of them. About 120mm x 30mm, one end rounded and 2 bolt
holes. Is there a way to estimate the cost? For example, £45 per hour for the cutting machine with a laser speed of 5cm per second, plus the 0.7m2
of stainless sheet.
redturner
| posted on 8/8/14 at 11:50 AM |
Too cheap to worry about. I had some fancy shaped plates cut out of mild steel x 3 mm. Couldnt believe my luck when he said, 30 pence each..
| posted on 8/8/14 at 04:04 PM |
Each place will calculate slightly differently, including whether they have stock material and how well they can tesalate the parts. Always easiest
to submit a drawing and get them to quote.
designer
| posted on 8/8/14 at 06:11 PM |
Just send them a drawing and they will give you a price. They all charge different so why do it any other way?
smart51
| posted on 8/8/14 at 06:46 PM |
I want a guide price to see if I want to go ahead before I get quotes. If they're going to be tens of pennies each that'll be fine.
turbodisplay
| posted on 8/8/14 at 07:36 PM |
As a measure 8 plates 1.5mm, mild steel £1.5 each. 108mm diameter outside, inside 60mm ish.
