Author: Subject: O/T Removing a chimney
James
posted on 20/11/14 at 02:58 PM Reply With Quote
So, I want to take down an unused chimney at the back of my house.
It used to have the boiler from the Titanic at the bottom of it but that's has been replaced with a wall mounted combi 1% of the size and 100x the efficiency elsewhere.
Sorry for the picture quality.
[img] Description
[/img]
[img] chimney2
chimney2
[/img]
Any other hints and tips?
I've ordered a scaffold tower (yes, I know a ladder would have done- I'm a wuss!).
Any other tips on removing it? I want to save the bricks to re-use elsewhere?
I've bought timber to replace the hole in the joists, breathable membrane to fill in the gap in the felt, battons, roof tiles and aluminium nails.
Got a bucket and rope to lower the bricks etc. down.
Anything else I've forgotten?
Thanks!
James
v8kid
posted on 20/11/14 at 03:47 PM Reply With Quote
Tie the tower to the building - not the chimney ( yes I have done that or similar) The chimney might come down with a bang if it has acid corrosion from an old boiler. Don't get neurotic about it just position yourself carefully until you are sure its stable.
Have fun its a good feeling doing stuff like this.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
posted on 20/11/14 at 03:51 PM Reply With Quote
Don't wear anything you want to keep, if that chimney ever had a coal fire up it its going to be a very messy business.
And, its probably the weight of the concrete capping that's keeping it all together.
Enjoy!
posted on 20/11/14 at 04:58 PM Reply With Quote
Are you removing it internally as well right down to ground level?
James
posted on 20/11/14 at 05:17 PM Reply With Quote
Yes. Well, down to about chest height in the kitchen which is where it starts.
This previous thread is about the wall coming down and the chimney breast is part of this wall...
http://locostbuilders.co.uk/viewthread.php?tid=193299
James
tegwin
posted on 20/11/14 at 06:09 PM Reply With Quote
Chimneys tend to be pretty structural to a lot of houses..... I'd be very wary of removing it internally without a proper survey to see what is leaning against the chimney!
www.verticalhorizonsmedia.tv
snapper
posted on 20/11/14 at 06:34 PM Reply With Quote
My top tip
Start from the top
I eat to survive
I drink to forget
theprisioner
posted on 20/11/14 at 06:44 PM Reply With Quote
I have removed a few of these, the advice about tying the scaffold is sound. Usually they have to be caped off if anything remains below roof level as they can act as a fire conduit to and roof or ceiling space. One of the issues can be the lintel on the top but I see none on your chimney. Watch out for and undesirable fire proof material. Remove the lead flashing of course and fill in the sarking and repair the felt (or is that a Scottish ting). Make sure you have enough roof tiles of a matching kind.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
mookaloid
posted on 20/11/14 at 07:33 PM Reply With Quote
This
Mr Whippy
posted on 20/11/14 at 07:46 PM Reply With Quote
yeah that will be adding a lot of stiffness to the wall, i'd only take down whats above the roof
v8kid
posted on 20/11/14 at 09:41 PM Reply With Quote
Originally posted by snapper
My top tip
Start from the top
Bugger that's where I've been going wrong all these years
Cheers!
posted on 21/11/14 at 10:58 AM Reply With Quote
My top tip
Start from the top
Starting from the bottom is quicker...
...but you might earn a Darwin Award!
[Edited on 21/11/14 by David Jenkins]
James
posted on 21/11/14 at 06:00 PM Reply With Quote
This
Thank you.
We've had a structural engineer round as the chimney is part of a supporting wall we're having out soon.
See the link I posted above.
Anyway, the scaffold tower 90% up now so let's see how this goes.
James
P.s. Dark, raining and ill, bad time to continue scaffolding now? I better have a beer to warm me up!
James
posted on 26/11/14 at 06:00 PM Reply With Quote
Quick update....
[img] Scaffold
Scaffold
[/img]
[img] Nearly done!
Nearly done!
[/img]
Getting there.
Thanks for the advice, will finish up and put the roof in properly this weekend I hope!
James
