John P
| posted on 9/12/14 at 06:00 PM |
Fitting an Outside Socket
I'd like to fit a permanent outside socket to avoid running extension leads from the house.
I was thinking of running a spur from the back of a socket on the ring main to a fused RCD and then to weatherproof socket but having done some
searching I'm confused about whether the separate RCD is necessary or even a good idea as the whole ring main is protected by an RCBO at the
consumer unit.
Any advice would be appreciated.
John.
PS: I appreciate this probably should be done by a qualified electrician but if at all possible I'd like to do it myself. (Pre Part P I did
quite a lot of electrical work and even worked in the electrical department of a factory for a while).
cliftyhanger
| posted on 9/12/14 at 06:20 PM |
I would run the spur as suggested, probably put a dp switched fused spur inside the house if convenient/possible. No RCD requied as protection is
already there. And do it myself.....
serieslandy
| posted on 9/12/14 at 07:55 PM |
That's exactly how my dad has his and he is an electrician.
I've got mine coming straight off the consumer unit on a seperate mcb.
motorcycle_mayhem
| posted on 9/12/14 at 09:14 PM |
Mine comes off it's own independent RCBO. Single 2.5mm T+E is deemed OK, set up as a spur on a 16A by the guys that installed and certified the
100A feed out to the garage CU.
The wife tested it, cutting the electric hedgetrimmer cable twice in one day. Protection worked beautifully, would've been catastrophic
otherwise.
dhutch
| posted on 10/12/14 at 12:57 PM |
Sounds about right to me.
Mines a spur of a RCD+MCB protected ring, DoublePole with Neon so you can isolated a fault, but it is unfused.
Daniel
