scotty g
| posted on 12/12/14 at 11:27 AM |
cutting and working with Perspex, best tools/techniques
Hi all,
as above really, what's the best way to cut sheets of perspex, I need to cut up some big sheets of the stuff to put all around the kitchen as
splash backs but I have never worked with the stuff before so thought some of you guys might have some experience.
All advise gratefully received.
Cheers.
[Edited on 12/12/14 by scotty g]
scotty g
| posted on 12/12/14 at 11:38 AM |
Oops.
Had to edit my post as it isn't acrylic but perspex (not sure what the difference is).
bi22le
| posted on 12/12/14 at 11:50 AM |
We work with acrilic and perspex. They both present the same problems whe doing the work you speak of.
For long cuts use a band saw if you can with a wood cutting blade. If you need to use a jig saw for plugs then use an upward facing toothed cutter
(Backwards to normal) as it is less likely to chip the plastic. Make sure you dont use metal blades as it just melts back to gether. Keeping the blade
cool and moving is key. Use a router or power file to finish off the edges depending on the finish you want.
I take it you have already purchased the the plastic?
If not I can give you the BEST tip of the year!!
Go to formica supplier and use that instead. I did this in my kitchen and it looks amazing. I used cheap 8mm MDF as backing \ template. Once I was
happy I contack adheisive on my bright green (ooohh yeah!!) formica and routed round to get a perfect finish, including the plugs. THen just no more
nailed it to the wall.
In glass it would of cost 1000's in plastic 100's in formica it was about 250 for the whole kitchen splash back, approx 8M worth from top
cupboards down to work surface.
It looks the nuts with down lights.
Please read my ring story:
Irony
| posted on 12/12/14 at 12:24 PM |
Perspex is a brand name. Your probably talking about polycarbonate. Polycarbonate is a very tough substance that face masks and riot shield are made
from. Its also very expensive when compared to acrylic. Acrylic looks more or less identical to Polycarbonate but acrylic is far less tough. This
means however you can work with it easier. Its very difficult to tell them apart from looking at them but if you grind one of them you get a fruity
sort of smell and the other doesn't. I can't remember which one it is though.
Both materials can be cut with standard woodworking tools but poly will blunt them quickly. I would buy the pieces cut to size myself as a bench saw
or wall saw is preferable. Acrylic will shatter, if you jar it to much. Also if to much heat is applied during cutting the plastic will fuse back
together behind the blade. Which is just plain odd. I have run sheets of acrylic/polycarbonate through bandsaws before and been left with a single
piece of plastic again.
I have a huge sheet of 10mm thick acrylic as my shower panel. I had it cut and polished to size. When attaching it I had to make the holes for the
bolts a few mm bigger than the bolts as it swells and contracts a lot when the warm water hits it. It's still fine after 3 years.
I would get it cut to size by a professional myself. I can utterly recommend
http://www.trentplastics.co.uk
dhutch
| posted on 12/12/14 at 12:41 PM |
Perspex is a trade name for Acrylic (Plexiglas in the US) , as said, with but Polycarbonate (or Lexan, to use a US trade name..) being the other
commonly used plastic.
One of the problems is that both can have the properties changed a lot depending on the process and fillers, etc.
Most common issues asside from scratching stem from uncontrolled splitting or tearing if the tool jams causing a point load.
If its a tough enough grade, scoring and folding can work for straight cuts, is if it brittle enough scoring and snapping like glass can also work.
Otherwise I would be reading internet sites for advice as the must be plenty out there.
Daniel
HowardB
| posted on 12/12/14 at 04:02 PM |
in the true theme of "man kitchens" mine had brushed stainless steel splashbacks,... bought, folded, and no-nails to the wall. Sockets
holes and other features cut without issue.
I'll look for some pictures,..
Howard
scotty g
| posted on 12/12/14 at 04:33 PM |
Just to update on progress.
Marked the sheet and lined up the jigsaw, clamped a long length of melamine kickboard down to act as a guide for the jigsaw but it wouldn't cut
straight.. Broke out the rip saw which did cut straight but, well, ripped!!!!! Then tried a brand new blade in the jigsaw and it cut a treat, as long
as i kept the motor speed high and my push rate low it cut a lovely smooth straight line. I may have nicked the leg on our nice new oak table a bit
but hopefully the missus won't notice that! Ahem. All packed away for the night now so will finish the cutting tomorrow then get it all glued
up.
Thanks for the info guys, much appreciated.
Davey D
| posted on 12/12/14 at 07:40 PM |
On the subject of polycarbonate. Is there an easy way to bend it? I have a part I need to make from 6mm polycarbonate. It's only around 150mm
wide but I need to bend it to around 140deg.
