bart
| posted on 17/3/15 at 10:18 PM |
copper tube
looking at the dimension's shirley ( stop calling me shirley ) 15 mm copper tube would do the trick with 90 deg elbows at each end.
you can bend "new soft" copper tube over your knee the amount you need in the picks.
you might mess a few up but its not that expensive.
if you want to get really tech cap off , fill with sand ram down till hard cap the other end off then bend away no crimping
use a piece of drain as a mandrel. you could always run a blow torch over before to anneal the tube.
with sand bet you could do larger as well.
BE ALERT > BRITAIN NEEDS LERTS
| posted on 17/3/15 at 10:30 PM |
Get a plumbers spring! Thats what you use to bend over your knee.
What you making like??
bart
| posted on 17/3/15 at 10:44 PM |
got posted wrong
got posted wrong , must have hit new topic without realising
was in response to some Arial question some one posted .
he was trying to make a long spiral
bart
| posted on 17/3/15 at 10:50 PM |
next random post
my next random post will be !
12" insert forcefully using lubricant, twist if necessary , use tie wraps if that helps .
" but that was the wrong forum all together"
Angel Acevedo
| posted on 17/3/15 at 11:16 PM |
Not just "someone "...
It was THE boss...
Better put your stuff right...
Hhhh...
HowardB
| posted on 18/3/15 at 07:29 AM |
I like the idea of wholly random posts,....
how about?
I would have seen it but it was foggy and I was asleep.....
Howard
gremlin1234
| posted on 18/3/15 at 12:49 PM |
how about?
that'll be the eclipse on Friday!
scudderfish
| posted on 18/3/15 at 07:27 PM |
I finally managed to explain myself and had a good laugh about it with the judge.
HowardB
| posted on 18/3/15 at 07:47 PM |
how about?
Sadly it was the aurora....
Howard
