John P
| posted on 2/6/15 at 06:09 PM |
Domestic Wiring a 4 Gang Switch - Help Please
I’m redoing our kitchen and eventually we will have a central light, recessed spots in the ceiling, under-cabinet lights and also plinth mounted
lighting.
Ideally I would like to fit a 4 gang switch inside the door to control these individually but how is it best to wire these?
I assume I could bring a single live to the switch and loop from this to all the individual switches. I would then need 4 separate switched lines
plus an earth so presumably I’d need cable with 5-cores and an earth but is this available / acceptable.
If it’s OK how would it be best to arrange the neutral / earths to each of the various lights.
John.
owelly
| posted on 2/6/15 at 06:17 PM |
I would loop in to each light fitting and then run a switched cable from each fitting to the switch.
http://www.ppcmag.co.uk
| posted on 2/6/15 at 07:11 PM |
Myself, I'd run a twin and earth to feed the switch (live and neutral), use short crosslinks to feed all 4 switches, and run an individual twin
and earth to each light. Link all the neutrals in a connector block.
This work would be notifiable to building control.
big-vee-twin
| posted on 2/6/15 at 07:43 PM |
Single Red and Earth to the switch from 6 amp MCB, loop to all 4 switches. Earth to the back box.
Single Red and Earth from each switch to each group of lights- Red from switch and earths from back box.
Single black looped around each lighting circuit back to consumer unit neutral.
http://www.triangleltd.com
SteveWalker
| posted on 2/6/15 at 08:43 PM |
Personally, I'd put an accessible box in the ceiling, fed with live, neutral and earth by a standard Twin and Earth cable.
I'd feed each light (or set of lights) from the junction box, with one of four standard T&E cables.
I'd then drop the required cables from the junction box to the switch, sleeving all the (non-Earth) cores brown. What you drop is up to you - 4
individual T&Es; three T&Es with two pairs of switches, each fed from the cores of one cable and the returns on the other two; One T&E and
one Three core and Earth cable, with all switches fed from a single core. The last option is the simplest, as it has the fewest earths to try and
terminate in a single terminal and the fewest number of cores filling the back box.
Neutrals shouldn't be present at the switch backbox anyway and using individual T&Es to each light or set of lights means no problems when
redecorating in the future.
When I wired my house I did something similar - although a little more complicated, as I have two separate ceiling lights and two separate wall lights
in a through room, 2-way switched by 4-gang switches at either end of the room. Despite laying them out logically and identically at each end of the
room, it's like a disco in here when my wife wants to turn a light on or off - myself and the kids have no problem!
[Edited on 2/6/15 by SteveWalker]
AntonUK
| posted on 2/6/15 at 09:35 PM |
ditto
Build Photos Here
slingshot2000
| posted on 3/6/15 at 08:42 AM |
ditto
ditto
slingshot2000
| posted on 3/6/15 at 08:43 AM |
Red and black twin and earth has not been readily available for about ten years, it has been brown and blue since then.
