mikeb
| posted on 5/4/18 at 09:46 AM |
Anyone changed a combi boiler PCB
My boiler has been playing up, its a Vaillant ecotech plus (not sure on age but probably under 10 years).
Its throwing a F.62 fault code, a reset would keep it going for a week but now it throws the fault everytime you stop the hot water tap.
Interweb says 9/10 PCB fault 1/10 gas shut off valve.
I need to double check the part numbers but it looks like this
https://www.dhsspares.co.uk/product/vaillant-0020132764-printed-circuit-board-1383245?gclid=Cj0KCQjwkpfWBRDZARIsAAfeXapNOs5n776lK3JFhluRWrujaXUHsaeNM4
O36vlQKMfPYiSfiOGYuzEaAq7EEALw_wcB
I've had the front off 6 months ago to fit my hive receiver so I know I can get to it all.
But when you google, comments come up, do you know how to complete the safety check after install etc which got me a little worried.
Any tips, or just fork out for the pros?
Mike
[Edited on 5/4/18 by mikeb]
big-vee-twin
| posted on 5/4/18 at 12:51 PM |
If your not touching the gas side of things I wouldn't worry about it.
If your changing gas valve you have to be a competent person, which you are if you are contemplating the repair.
Get some leak spray when you turn gas back on use it to check for leaks, did mine few years ago easy to do no probs if you can build a car.
http://www.triangleltd.com
mikeb
| posted on 5/4/18 at 12:57 PM |
I wouldn't touch the gas side, just changing the PCB. Didnt' know if there are settings that need to be programmed in.
Charlie_Zetec
| posted on 5/4/18 at 12:59 PM |
Done boiler PCB's a couple of times without issue. Just turn off the power supply (should be on a fused spur or its own feed from the breaker
board) and disconnect/connect and fit. It's the gas side of things that I wouldn't touch, and would get someone in to do. Depending on
the size/style of the PCB, you might want to invest in an earthing bracelet/strap, although not a requirement.
chris
| posted on 5/4/18 at 10:36 PM |
no there shouldnt be any reprogramming required just make sure you have isolated the power before you start and when you switch it back on the boiler
may go into a test mode just let it run
Mr Whippy
| posted on 6/4/18 at 11:40 AM |
no done this many times due to cracked boards, gas boilers are hellish for this. Very easy just unscrew and unplug the board (power off) then switch
on and is should work. Have a look on the web, it's one of the main faults with gas boilers.
daKlone
| posted on 13/4/18 at 10:57 PM |
As others have said, it's pretty straightforward to do. I'd just add that it's worthwhile taking a few pictures before you remove
anything, just to recall where the connectors and bits go. You might not need it, but better to have it just in case.
Also, I would be careful where you buy from. I got one that was apparently "new", and did look it with it's nice new box, but I
fitted it and it didn't work. Had to send it back for a replacement...along with the usual "I've never had this happen before"
platitudes from the seller. That was from eBay though, so I guess you take your chances...
dK
Winter is coming...
adam1985
| posted on 14/4/18 at 01:09 PM |
You still need to be gas safe registered to replace the circuit board on a boiler, the pcb is what controls the safety devices for the appliance do
you know how to test these? The front cover is part of the combustion chamber on this boiler so this shouldnt be removed by anyone unless gas safe. In
the last 10 years rules have changed with flues has yours been checked to make sure its safe? Also on those boilers the heat exchanger seal is
required to be changed every 5 years.
Personally i would get somebody competant to work on vaillants weather thats a local guy or the manufacturers.
