liam.mccaffrey
posted on 9/4/18 at 12:07 PM |
Tintop Bodywork Question
I have an 87 Volvo 240 and I want to remove some of the ugly exterior trim. This would leave approx 40 x 4mm holes in the various body panels. Just
wanted to get your opinions on the best way to achieve this. I have both mig and tig available to weld them up but I'm significantly more
confident with MIG.
Thoughts??
Liam Mc
Build Blog
Build Photo Album
cliftyhanger
posted on 9/4/18 at 12:27 PM |
mig is ideal. I am always filling holes with mine, often where a few seconds before there was what looked like good steel![](/images//smilies/shocked.gif)
posted on 9/4/18 at 01:07 PM |
If you're more comfortable with MIG then I'd go with MIG.
From experience welding thin sheet (tin top) takes a bit of getting right to avoid blowing holes in it. There are some good videos on YouTube talking
you through the process.
jelly head
posted on 9/4/18 at 05:28 PM |
If you can get it behind the panel then a dissimilar flat heat sink will help behind the holes.
posted on 11/4/18 at 07:49 AM |
Some recommend blowing the weld area with compressed air (if you have it) between each weld to help minimise heat distortion.
Angel Acevedo
posted on 11/4/18 at 03:08 PM |
Performing a countersunk lap seam may help reduce blow through...
