russbost
posted on 24/5/18 at 08:48 AM |
Help with UPVC door handle
I have to replace a UPVC door handle set, front door, inner & outer handles as the thread has stripped from one of the screw locations
They are a really weird size & setup
Overall length width of the casing is 205 x 30
Locating screw centres are 164mm (poss 163 or 165)
The operating handles are offset, ie one is higher than the other 62pz one side, 92PZ the other
I cannot find anything that matches anywhere, I can find handles with the right offset 62 & 92PZ but they are longer
Q is this, either, does anyone know what I've got & where I can replace
OR if I replace with a longer handle set, how likely is it that if I try to redrill holes for the new screw positions they will foul parts of locking
mechanism - I don't really want to have to strip all the locking mechanism out to find out
Any advice welcome!
posted on 24/5/18 at 09:12 AM |
Recently had to replace a couple of closing mechanisms on some UPVC windows. Easy enough to strip out, but same as you a bugger to find like for like
replacements. I ended up going back to the company that fitted the windows who were able to supply the correct (OEM) mechanisms.
Do you know either who manufactured or fitted the door?
They may be the people to ask for spares!
watsonpj
posted on 24/5/18 at 09:38 AM |
Russ have you tried taking the parts to dg supplying on the 127 Southend. I have some old units and they have been able to supply equivalent parts but
also give advice on how to rework.
Pete
russbost
posted on 24/5/18 at 10:16 AM |
No idea who manufactured the door, it's in a rental property & no ID that I can see on it
russbost
posted on 24/5/18 at 10:20 AM |
Pete
Is that DG Supplyline at Westcliff? If so they only show one offset handle set on their website which is 215mm centres .........
Slater
posted on 24/5/18 at 01:38 PM |
I had exact same issue about 1 yr ago, ended up driving round various door/window factories with the old handle until I found one that had spares.
Think it was a specialist door handle place that had them, 40 quid for a new pair.
Here is a link if it helps.. maybe give them a call, they were very helpful, my handles were pretty old and not on their website.
Linker
posted on 24/5/18 at 01:55 PM |
No chance of re-tapping the thread - maybe slightly bigger diameter?
russbost
posted on 24/5/18 at 02:35 PM |
I doubt it, there's not much "meat" around those die cast ali threads, if I'm really stuck I guess I could drill thro'
& put a length of studding in there with some domed nuts on so it looks pretty
posted on 24/5/18 at 04:06 PM |
Fair point, there's certainly no spare metal them.
bart
posted on 24/5/18 at 10:50 PM |
I have a work shop next door to the best double glazing spares place in the country sells all spares for doors ect.if they don't do it.then
unlikely to get it anywhere else. I think there called doors and hinges I'll find out get back to you
BE ALERT > BRITAIN NEEDS LERTS
bart
posted on 24/5/18 at 10:54 PM |
https://www.handlesandhinges.co.uk/
posted on 25/5/18 at 09:27 AM |
Bookmarked - could come in handy one day
Slater
posted on 25/5/18 at 10:37 AM |
Originally posted by bart https://www.handlesandhinges.co.uk/
That's an excellent website! You gotta love this forum!
russbost
posted on 25/5/18 at 12:10 PM |
Unfortunately doesn't look like they do anything like it either, looks like I need to strip out the door mechanism & see if there space to
redrill holes further out
jacko
posted on 25/5/18 at 02:02 PM |
how about a self taping screw to replace the bolt
russbost
posted on 25/5/18 at 02:07 PM |
That's precisely what someone had done in the past! & hence mashed the thread in the handle for about 2/3rds of it's length,
it's holding at the moment, but I really can't trust it, plus as the handle is old & worn it's only a matter of time b4
something else lets go on it - I don't just want to move it on to be a problem again in another 6 months time or whatever, hence why I wanted to
replace the whole handle set (preferably with something that's easier to get a replacement for in future!
Angel Acevedo
posted on 26/5/18 at 02:51 PM |
Fill with plastic steel putty, re-drill and re-tap?
HTH
