number-1
| posted on 4/1/20 at 03:52 AM |
Towel rad fittings
Bit of a random question but..... does anyone know if you can by mounting brackets for a towel radiator that are shorter than standard ones? I think
the normal ones are about 80-90mm. Ideally im after ones that are the same depth as a normal wall mounted rad bracket. If not ill cut down the ones i
have
N1
Duncan Grier
| posted on 4/1/20 at 07:19 AM |
Sure the general length of the shorter ones are 60mm iirc. In an old property I needed to mount one closer to the wall due to access through the door.
I cut / tweaked no issues
macc man
| posted on 5/1/20 at 03:04 PM |
I tend to cut the plastic ones down. The metal type are harder to shorten and may need the fixing hole drilling and tapping.
Not a big job.
