smart51
| posted on 12/3/20 at 11:02 AM |
Can anyone do me a quick DXF drawing?
I would like to have some laser cut steel, but I need a DXF drawing. It's a simple bar with round ends and 3 circular holes as in this
sketch:
  stap
If you're good with CAD, could you do me a favour and draw up my sketch please? Ta!
| posted on 12/3/20 at 12:03 PM |
Sadly I don't have access to CAD software anymore or I would.
You might ask "Loggyboy" on here - IIRC he can do this kind of thing.
loggyboy
| posted on 12/3/20 at 12:14 PM |
All done and saved here:
https://1drv.ms/u/s!Ap9mOeT8wwLkrm-ovaVj0DUzpj87
[Edited on 12-3-20 by loggyboy]
Mistral Motorsport
loggyboy
| posted on 12/3/20 at 12:31 PM |
You can view it to check it by registering here
https://viewer.autodesk.com/designviews
Mistral Motorsport
smart51
| posted on 12/3/20 at 12:37 PM |
Wow that's great! Thank you!
loggyboy
| posted on 12/3/20 at 12:46 PM |
No problem, let me know if its not as you sketched, - but should be ok, its simple enough even for me!
Mistral Motorsport
smart51
| posted on 12/3/20 at 10:21 PM |
I submitted the DXF for quoting. I've had 2 back. £60 and £70. The £70 guys did say that was their minimum order and that I could have 53 cut
for the same price if I wanted them. Is that about right for laser cutting. Cheap enough each, but you've got to have loads done?
Fred W B
| posted on 13/3/20 at 06:23 AM |
You don't spec the thickness, and is it only one? If its 1.6, 2 or 3 mm thick you could have made one out of 20 mm flat bar with a hacksaw,
grinder or file and drill by now.
Regards
Fred W B
[Edited on 13/3/20 by Fred W B]
smart51
| posted on 13/3/20 at 07:00 AM |
I asked for 3mm thick mild steel and wanted 5 of them, but that's bye the bye. The £70 guys have a £15 set up fee and charge about £1.50 each
for the parts. Rather than sell me 5 for £22.50, they say £70 minimum order, you can have 53, or any quantity less than that for the minimum price.
WallerZero
| posted on 13/3/20 at 07:35 AM |
Have a look at watercutting, generally cheaper, especially if you can provide the material
http://zachsgbszero.blogspot.co.uk/
MikeR
| posted on 13/3/20 at 11:10 AM |
Some people fit parts into other jobs if you're not in a rush. Unfortunately I can't remember anyone who does right now.
coyoteboy
| posted on 15/3/20 at 09:57 AM |
You're paying for someone's time and skills, not the metal. Setup charges are usually the big cost on small stuff like this. They might
say the set up fee is 15, but it's not, the reason the moq is there is to cover the setup.
As mentioned, you'd be better with a hacksaw and grimder if 70 quid for a custom part is too much. A laser or wj cutter will likely still need
your holes opening up to the correct diam.
[Edited on 15/3/20 by coyoteboy]
Big T
| posted on 15/3/20 at 06:57 PM |
Do you still require this doing? I do it for a living so drop me a message and hopefully we can sort something out. Very happy to help.
Big T
| posted on 15/3/20 at 06:58 PM |
I’ve just seen you’ve had this sorted, although I’ll leave the previous reply there for anyone else that searches it in the future. I have access to a
plasma and laser, so if anyone does need anything please drop me a message.
