jps
| posted on 4/4/20 at 12:54 PM |
Dishwasher woes...
I’ve got a built in AEG dishwasher that has stopped behaving. In locost spirit I’d like to repair it, but running out of ideas, so thought I’d try on
here...
The model is a few years old and pretty basic (it came ‘free’ with a Wickes kitchen) with just 3 different heat options and a rinse cycle. It stopped
working a few months ago, which I diagnosed as overfilling and triggering the ‘flood’ switch. I found out there is what I assume is a sort of float
switch piped off from the sump that was all clogged with fat. I cleaned it out and all was sorted. I assume the fat was stopping the float switch
getting enough pressure unless it had a greater head of water above it - and that switch was the one that cut the water supply (hence the overfilling
and subsequent flooding).
With hindsight I realised that the machine was very full with water when running, prior to this first fix. After I fixed it it ran with hardly any
water visible in the bottom of the machine.
Now the machine is stopping, seemingly because it is not pumping out fully, fairly early on in a cycle. I’ve checked the previous issue, all is clear.
The machine doesn’t seem to be overfilling, water level in operation looks ok, and the flood switch isn't getting tripped.
I’ve checked the pipe that drains the dirty water from the sump, totally clear where it exits. And if I stick a load of water in the machine by hand
it pumps it all out (I’ve run several kettle fulls of hot water through).
Last time it was faulty we tried 4 different repair men, no one turned up. So keen to try and fix it myself again!
Mr Whippy
| posted on 4/4/20 at 03:18 PM |
May sound a bit mad but I pour a cup of bleach in ours empty and run it at full temp then 2 times with just the tablet to clean out any trace of
bleach. I also do this with the washing machine, certainly seems to sort them out.
bi22le
| posted on 4/4/20 at 09:45 PM |
So it's not throwing up a fault which is stopping it from working? It thinks it's doing the job but not?
Please read my ring story:
Angel Acevedo
| posted on 5/4/20 at 02:16 PM |
For grease deposits, I´d think drain cleaner or other caustic cleaner would be etter suited to this job?
| posted on 5/4/20 at 04:02 PM |
Don't use bleach if your machine has stainless steel parts inside - it will cause corrosion, usually appearing as etching on the surface.
If you don't believe me, just Google "bleach and stainless steel".
Oh - and if your machine has aluminium parts inside, don't use caustic solutions.
[Edited on 5/4/20 by David Jenkins]
jps
| posted on 5/4/20 at 08:28 PM |
Sorry for the slow reply, been enjoying the sun! The error (which is indicated by a pattern of beeping, this thing has no lcd display!) seems to
indicate it’s a water supply problem, so tomorrow I’ll be checking the inlet valve and the mesh filter that sits between the valve and the inlet
solenoid...
craig1410
| posted on 5/4/20 at 11:58 PM |
Something you might want to check is if the “sump” is actually flooded. I had this problem with an Ikea dishwasher where it actually has a float
sensor in the panel BENEATH the dishwasher which is designed to catch any overflow before it floods your kitchen. It’s literally a panel underneath
the dishwasher which is designed to catch any overspill and on my machine was indeed flooded. I fixed the blockage inside the machine which was
causing the spillage and then drained and mopped up the water in the sump and all was well!
Your owner’s manual might describe the sump as mine did, but like you, I thought the sump was the bit inside the washer where the filter sits.
HTH,
Craig.
Mr Whippy
| posted on 6/4/20 at 08:25 AM |
Possibly, I haven't seen any staining inside, but it is well diluted once the waters filled up. I must be doing something right as the machines
over 10 years old and still working perfectly despite daily use.
jps
| posted on 6/4/20 at 08:52 AM |
quote: Originally posted by craig1410
a float sensor in the panel BENEATH the dishwasher which is designed to catch any overflow before it floods your kitchen. It’s literally a panel
underneath the dishwasher which is designed to catch any overspill
Thanks - yes this is what I found out about with the first problem a few months ago. A good design feature I thought, but sadly not the problem this
time....
jps
| posted on 7/4/20 at 03:00 PM |
Bi22le - thanks for asking this question, it prompted me to go back to basics and check the error codes! I checked the inlet valve and - despite there
being no apparent blockage - I must have disturbed whatever was restricting the water feed. I don't want to count my chickens, but it's
done 3 cycles now with no more errors!
