| posted on 26/6/20 at 01:28 PM |
A new very random question... about double-glazing handles.
I have a wooden double-glazed window at the back of my garage, with a top-opening bit. The window is roughly 1220mm wide, and opening bit is roughly
250mm high. The builder who installed it fitted it with a couple of stays that work, but are a PITA as they limit how much I can open it. The window
is fitted with friction hinges at each side, just like a proper double-glazed window so I don't need stays at all, just something to lock it
shut when closed.
So now I'm going to fit the sort of handle/lock you find on most double-glazed windows - but my question is, do I fit one in the middle, or
should I fit two nicely spaced apart? I suspect that one will be enough, but I don't know what's normally done.
All advice gratefully received!
| posted on 26/6/20 at 01:59 PM |
Our house UPVC double glazed windows are 1.1m x 1.1m top hung fully opening. They have single locking handles bottom centre of each window. Work
perfectly well on the friction hinges. I fitted opening limiters to the kids bedroom (1st floor) Windows to prevent accidents when they were younger.
The limiters can be manually overridden if required for fire escape.
I'd suggest a single centrally placed locking handle will be sufficient.
steve m
| posted on 26/6/20 at 03:17 PM |
All of my windows over one metre wide have two handles,
But that does mean when you open a window, you must use both hands, on both handles, to avoid overstressing the glass
If you only had one handle in the center, this wouldn't be a problem,
For security, I would go for two
steve
| posted on 27/6/20 at 07:55 AM |
I'm sure you know this but make sure you fit ones that can't be snapped to gain entry. Lots of euro style locks still in use are childs
play to open.
