snakebelly
posted on 25/4/22 at 06:33 PM |
Duratec Turbo / Supercharged parts kit FS
Final bits of my pre emigration clearout.
Photos here:
Kit of parts to build a turbo / supercharged 2 litre Duratec.
Contains:
1. Duratec 2.0 Short block, chemically cleaned and bead blasted, bored to suite pistons below.
2. Set of new max overbore Wossner forged low compression pistons.
3. Set of new PEC h beam conrods
4. Set of King Race std sized Mains bearings.
5. Set of Mahle Std sized big end bearings.
6. Genuine ford timing chain tensioner.
7. Febi timing chain.
8. New front crank seal.
9. New rear crank seal.
10. Used crank, may need a polish.
11. 2 X Duratec high port heads, may or maynot have valves fitted but all the caam caps are present.
12. New Rotrex supercharger mounting bracket to suite Duratec, includes 2 face plates for either rotrex option.
13. New alloy charge air cooler.
14. New Ford oe electric water pump for use with charge air cooler.
15. Good condition alloy front cover.
16. Good condition standard sump.
17. Good Condition plastic cam cover.
18. New Cosworth clone inlet manifold.
Also a box of used parts, front pulley, piston and rods, timing chain guides etc.
Looking for offer over £900 the lot! collection required ASAP.Photo Link
[Edited on 25/4/22 by snakebelly]Photos Link
snakebelly
posted on 28/4/22 at 11:14 AM |
Price dropped to £800 all in but must be collected before end of day this sunday from either TF9 2JH or SY7 9PQ
snakebelly
posted on 29/4/22 at 12:24 PM |
any interest at £700, any lower than this and ill; chuck it all into storage.
Mac
