| posted on 6/5/22 at 12:18 PM |
2-pack zinc chromate primer disposal
Before anyone says it - I know that this is nasty stuff, but I only used to brush it on, in very small quantities...
I'm in the midst of a massive garage clear-out, and now I'm onto all the stuff that you can't take the the usual council tip - paints,
old coolant full of anti-freeze, brake fluid, & stuff like that. I intend to pay for a 'hazardous materials' collection with the local
council's refuse department (it's subsidised, but still has to be paid for - hopefully not too expensive).
During this process I came across 1 tin and 1 container of 2-pack chromate primer, well over 15 years old, which I'd like to put into a less
hazardous state before it's collected.
Would it be a seriously exothermic reaction if I pour the catalyst into the base material? There's enough room in the can. Probably it would
just set, but I really don't want a can of overheating nasty stuff in my garage!
The reason for asking this is that a while ago I had a can of old fibreglassing resin that I wanted to get rid of, so I put some hardener in it -
thankfully it was in a metal container, as it got VERY hot!
obfripper
| posted on 6/5/22 at 12:39 PM |
It won't get hot as polyester resin does so should be fine, but you may find the hardener has gone solid anyway. It will usually last 2-3 years
if unopened, and around 6-12 months once opened and exposed to the air/moisture.
Dave
| posted on 6/5/22 at 01:31 PM |
The hardener is still liquid - but I have no idea how effective it will be after 15+ years!
Nice to know it won't get all nasty on me though - but the stuff really stinks, even when in the open air, so I doubt that I'll be popular
with the wife while it goes off...
