Author: Subject: Plastic light and earth?
number-1
posted on 5/1/24 at 06:35 PM Reply With Quote
Evening All
Does anyone know if a plastic outside light needs an earth? The entire shell is plastic and as far as I can see the only metal parts are where the bulb screws in.
The reason I ask is there is nowhere to attach one and the previous light (metal) did have a location for one
N1
jacko
posted on 5/1/24 at 07:26 PM Reply With Quote
Yes it does it will need two wires live and nuteral
555
cliftyhanger
posted on 5/1/24 at 10:21 PM Reply With Quote
There is usually an earth terminal, even if it serves no function.
If not pop the bare earth wire in some sleeve and fold it over/tuck it away. There should be instructions with the light fitting which overrule any regulations.
The light will need to be covered by an RCD for safety. Many properties had split load boards fitted about 25 years ago, where power circuits were on an RCD and the light circuits were not. So do check.
posted on 7/1/24 at 03:36 PM Reply With Quote
Our house was wired like this!
Re-wire with a new consumer unit corrected things.
cliftyhanger
posted on 7/1/24 at 04:30 PM Reply With Quote
I have sorted a few, by adding an extra RCD in the board, or making the whole board protected by the one RCD. Or even swapping the non-rcd breakers for RCBOs. Saves the client a small fortune.
My nephew has just bought a flat, no RCD at all in the board. I will replace the mainswitch with an RCD for him. Simple, and with a small number of circuits, quite acceptable,
number-1
posted on 7/1/24 at 06:06 PM Reply With Quote
Thanks for the replies chaps
Apparently the plastic light is double insulated so doesn't need an earth as its class II? I have wired it up leaving the earth unconnected and covered up and it seems to work ok.
N1
coyoteboy
posted on 9/1/24 at 04:04 PM Reply With Quote
My whole house is protected by wire fuses and a single RCD on the incoming line, straight after the meter and main fuse. One slight slipped wire and the whole damn house is down
One day I'll replace the consumer unit.
