Author: Subject: Front Grille
shortie
posted on 17/3/05 at 08:08 PM Reply With Quote
Front Grille
Just trying to work out the best way of fitting the front mesh grille.
any ideas?
ta,
Rich.
jacko
posted on 17/3/05 at 08:19 PM Reply With Quote
SIKAFLEX
jacko
Donners90
posted on 17/3/05 at 08:33 PM Reply With Quote
I 'glued' (car body filler) wooden blocks on the inside of the nosecone then used penny washers and and wood screws.
Piccies here
http://www.locostbuilders.co.uk/viewthread.php?tid=23757
HTH
James
phelpsa
posted on 18/3/05 at 09:01 AM Reply With Quote
Cable ties!!
JAG
posted on 18/3/05 at 09:17 AM Reply With Quote
I made my grill from 2" square weld-mesh.
I left two prongs sticking out top and bottom. Then drilled two matching holes in the top and bottom of the grill opening and slotted it in.
It could come out on it's own but hasn't yet. I stole the idea from Caterham
Justin
Nick Davison
posted on 29/3/05 at 04:14 PM Reply With Quote
Rich
What type of grill material are you using and where did you get it from?
Nick
lenny
posted on 29/3/05 at 04:43 PM Reply With Quote
have a look in my archive under body s/steel 1" mesh out of a filter from a big air extrator airduct about 500 x500 and it woz FREE all the better, still got a bit left Lenny
Marcus
posted on 29/3/05 at 07:20 PM Reply With Quote
B&Q are selling mesh suitable for grilles in aluminium for £15 (500x400 I think)
Marcus
Marcus
Because kits are for girls!!
tiffshaw
posted on 30/3/05 at 03:38 PM Reply With Quote
Try www.car-mesh.co.uk
Really high quality woven mesh available in polished stainless and black powder coat.
Chris.
posted on 30/3/05 at 08:00 PM Reply With Quote
I got some nice expanded ali from my local boy-racer emporium - around £12 - £15. It's the stuff the Gary-boys put behind the grille openings on their Saxos, Novas, etc.
I fastened it the Westfield way - tie-wraps through discrete little holes in the rim of the opening. If you choose the colour carefully you can barely see them (unless you get close).
alfasudsprint
posted on 30/3/05 at 11:40 PM Reply With Quote
Recently finished mine, I used GRP resin to glue bolts onto inside of nose cone, the mesh simply fixes onto these (2) with a support nut and large washer, then another nut. The mesh was from a roll of course, so the fixings squash it flat. Mesh is square holed steel, heavy guage. its different and wont kink easily like so many others.
