New Topic New Reply
Author: Subject: herald bushes????
kaymar
posted on 6/4/05 at 05:29 PM Reply With Quote
herald bushes????
the book mensions herald bushes for use with book arms but i cant get any local supplier to trace them i have tried qhy419s this also draws a blank any sugestions regards martin
Kevin
posted on 6/4/05 at 06:20 PM Reply With Quote
bushes
Hi! About a month ago I went to a motor factor called Mill Auto Supplies and showed them the Ron Champion book and got about 20 off the self. I live in Cornwall.
Kevin
nige
bushe,s
try rimmer bros of lincoln
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
Mark Allanson
posted on 6/4/05 at 06:33 PM Reply With Quote
Any factor who sells QH stuff should either stock Y419's or be able to get them within 24hours. I got mine from Mill Auto's as well!
Ian Pearson
posted on 6/4/05 at 08:45 PM Reply With Quote
T.D.FITCHETT
Tel: 01952 619585/620434
Part No: 119451
£10.00 for a set of 8
[Edited on 6/4/05 by Ian Pearson]
kaymar
posted on 7/4/05 at 12:11 AM Reply With Quote
thanx 4 the replys sourced them from triumph specialist @.85 each this evening cheers
mattpilmoor
posted on 7/4/05 at 06:23 AM Reply With Quote
Andrew Page do them
Measure twice - Cut once - Still f*!K it up!
NS Dev
posted on 7/4/05 at 08:22 AM Reply With Quote
I have a bag of them, leicester area, if anybody needs some.
JamJah
posted on 7/4/05 at 11:14 AM Reply With Quote
Recently i ran a simular post.
THe cheapest place I could find was TRGB. For 20 red (sports/ racing - been recommended more times than not) polys it worked out to be under £4 each. Obviously this is more than the blues or Landie's bushes but will give a better ride without having to remake your wish bones. Hope this helps
New Topic New Reply
