Author: Subject: ball joints for sierra hubs
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
Building: Haynes roaster in college with students, gulp!
posted on 30/5/05 at 05:17 PM Reply With Quote
What lower ball joints are people using with sierra hubs? or is nobody using them? Will the hub need machining, and if so, where can i have it done close to N. Wales?
posted on 30/5/05 at 05:42 PM Reply With Quote
mk2 astra joints are apparently a direct fit, but most get them reamed and use cortina or maxi parts. However, there are a lot of different joints that will fit - its just a matter of working out what! i had mine reamed at MK, near sheffield, but im sure most kit companies will do them.
tks
posted on 30/5/05 at 08:15 PM Reply With Quote
yeah
or you buy a item on an special shop
alixter or something
that reamer (hand reamer) will do exactly the job for a maxi one..
Tks
Danozeman
posted on 30/5/05 at 08:54 PM Reply With Quote
Most ppl use the maxi or cortina ones and get the hubs machined as said above. Ive gotta have a word with luego and take mine to get em done.
Dan
AGK7
posted on 10/6/05 at 01:00 AM Reply With Quote
Just wondering if someone could fill me in on what the Maxi ball joint is. We are familiar with the corti ones down here is Aus but i haven't heard of the maxi ones.
Any clues on what car this is off, a google came up with an early Dodge??
Thanks in advance.
Andrew
Australia
Rorty
posted on 10/6/05 at 03:49 AM Reply With Quote
agk, the Maxi was made by Austin in the UK and was a sort of shrunken Austin 1800 (virtually identical to the Leyland Tasman/Kimberly down here). The Maxi wasn't imported into Oz.
Cheers, Rorty.
